Recommendation for Block Cipher Modes of Operation: Galois/Counter Mode (GCM) and GMAC, NIST Special Publication, pp.800-838, 2007. ,
The Use of Galois/Counter Mode (GCM) in IPsec Encapsulating Security Payload (ESP), p.4106, 2005. ,
DOI : 10.17487/rfc4106
Recommendation for Block Cipher Modes of Operation: Methods and Techniques, NIST Special Publication, pp.800-838, 2001. ,
Optimized Galois-Counter-Mode Implementation on Intel Architecture Processors, Intel Whitepaper, 2010. ,
Using Intel AES New Instructions and PCLMULQDQ to Significantly Improve IPSec Performance on Linux, Intel Whitepaper, 2010. ,
CUDA Compatible GPU as an Efficient Hardware Accelerator for AES Cryptography, 2007 IEEE International Conference on Signal Processing and Communications, 2007. ,
DOI : 10.1109/ICSPC.2007.4728256
Efficient parallelisation techniques for applications running on GPUs using the CUDA framework, 2009. ,
Design of a Parallel AES for Graphics Hardware using the CUDA framework, Parallel and Distributed Processing Symposium, International, 2009. ,
SSLShader: Cheap SSL Acceleration with Commodity Processors, Proceedings of the USENIX Symposium on Networked Systems Design and Implementation, 2011. ,
PacketShader: a GPU-Accelerated Software Router, Proceedings of ACM SIGCOMM, 2010. ,
DOI : 10.1145/1851275.1851207
The Galois/Counter Mode of Operation (GCM) -revised, 2005. ,
