RAM: Rapid Alignment Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Several countermeasures against side-channel analysis result in misalignment of power traces, in order to make DPA more difficult. In this paper we propose a new algorithm to align the measurements after this desynchronizing through the variations of the internal clock, random delays, etc. The algorithm is based on the ideas of SIFT and U-SURF algorithm that were originally proposed for image recognition. The comparison with other known methods favors our solution in terms of efficiency and computational complexity.
978-3-642-27257-8_17_Chapter.pdf (582.76 Ko) Télécharger le fichier
hal-01596293 , version 1 (27-09-2017)
Paternité
Ruben A. Muijrers, Jasper Woudenberg, Lejla Batina. RAM: Rapid Alignment Method. 10th Smart Card Research and Advanced Applications (CARDIS), Sep 2011, Leuven, Belgium. pp.266-282, ⟨10.1007/978-3-642-27257-8_17⟩. ⟨hal-01596293⟩
106 Consultations
205 Téléchargements
