Fault Attacks on RSA with CRT: Concrete Results and Practical Countermeasures, Cryptographic Hardware and Embedded Systems ? CHES 2002, pp.260-275 ,
DOI : 10.1007/3-540-36400-5_20
Regular 2 w -ary right-to-left exponentiation algorithm with very efficient DPA and FA countermeasures, International Journal of Information Security, vol.52, issue.1, pp.363-370, 2010. ,
DOI : 10.1137/0205008
A note on efficient computation of cube roots in characteristic 3. Cryptology ePrint Archive, Report, vol.305, 2004. ,
A new CRT-RSA algorithm secure against Bellcore attacks, 10th ACM Conference on Computer and Communications Security, pp.311-320, 2003. ,
On the Importance of Eliminating Errors in Cryptographic Computations, Journal of Cryptology, vol.14, issue.2, pp.101-119, 2001. ,
DOI : 10.1007/s001450010016
Blinded exponentiation revisited, Fault Diagnosis and Tolerance in Cryptography ? FDTC 2009, pp.3-9, 2009. ,
DOI : 10.1109/fdtc.2009.31
CRT RSA Algorithm Protected Against Fault Attacks, Information Security Theory and Practices, pp.229-243, 2007. ,
DOI : 10.1007/11554868_13
On addition chains, Bulletin of the American Mathematical Society, vol.45, issue.10, pp.736-739, 1939. ,
DOI : 10.1090/S0002-9904-1939-07068-7
Resistance Against Differential Power Analysis For Elliptic Curve Cryptosystems, Cryptographic Hardware and Embedded Systems (CHES '99), pp.292-302, 1999. ,
DOI : 10.1007/3-540-48059-5_25
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1.5695
On Second-Order Fault Analysis Resistance for CRT-RSA Implementations, Information Security Theory and Practices, pp.68-83, 2007. ,
DOI : 10.1109/TC.2003.1190587
An RSA Implementation Resistant to Fault Attacks and to Simple Power Analysis, IEEE Transactions on Computers, vol.55, issue.9, pp.1116-1120, 2006. ,
DOI : 10.1109/TC.2006.135
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.667.9807
Highly Regular m-Ary Powering Ladders, Selected Areas in Cryptography, pp.350-363, 2009. ,
DOI : 10.1007/978-3-642-05445-7_22
Protecting RSA against Fault Attacks: The Embedding Method, 2009 Workshop on Fault Diagnosis and Tolerance in Cryptography (FDTC), pp.41-45, 2009. ,
DOI : 10.1109/FDTC.2009.32
Exponent Recoding and Regular Exponentiation Algorithms, Progress in Cryptology ? AFRICACRYPT 2009, pp.334-349, 2009. ,
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.477.1245
The Montgomery Powering Ladder, Cryptographic Hardware and Embedded Systems ? CHES 2002, pp.291-302 ,
DOI : 10.1007/3-540-36400-5_22
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.10.1502
High-precision division and square root, ACM Transactions on Mathematical Software, vol.23, issue.4, pp.561-589, 1997. ,
DOI : 10.1145/279232.279237
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.25.1679
Fault Attacks for CRT Based RSA: New Attacks, New Results, and New Countermeasures, Information Security Theory and Practices, pp.215-228, 2007. ,
How can we overcome both side channel analysis and fault attacks on RSA-CRT?, Workshop on Fault Diagnosis and Tolerance in Cryptography (FDTC 2007), pp.21-29, 2007. ,
DOI : 10.1109/FDTC.2007.11
Elliptic Scalar Multiplication Using Point Halving, Advances in Cryptology ? ASIACRYPT '99, pp.135-149, 1999. ,
DOI : 10.1007/978-3-540-48000-6_12
The Art of Computer Programming, 1981. ,
Differential Power Analysis, Advances in Cryptology ? CRYPTO '99, pp.388-397, 1999. ,
DOI : 10.1007/3-540-48405-1_25
Securing RSA against Fault Analysis by Double Addition Chain Exponentiation, Topics in Cryptology ? CT-RSA 2009, pp.459-480, 2009. ,
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.219.2374
Method and apparatus for protecting public key schemes from timing and fault attacks. US Patent #5, 1999. ,
RSA with CRT: A New Cost-Effective Solution to Thwart Fault Attacks, Cryptographic Hardware and Embedded Systems ? CHES 2008, pp.130-145 ,
DOI : 10.1007/978-3-540-85053-3_9
On the Evaluation of Powers, SIAM Journal on Computing, vol.5, issue.1, pp.100-103, 1976. ,
Checking before output may not be enough against faultbased cryptanalysis, IEEE Transactions on Computers, vol.49, issue.9, pp.967-970, 2000. ,
A countermeasure against one physical cryptanalysis may benefit another attack, Lecture Notes in Computer Science, vol.2288, pp.417-427, 2001. ,
A fast division technique for constant divisors 2 m (2 n ± 1), Scientia Sinica (Series A) XXVII, issue.9, pp.984-989, 1984. ,
