Acceleration of Differential Fault Analysis of the Advanced Encryption Standard Using Single Fault, Cryptology ePrint Archive, 2010. ,
Differential Fault Analysis of AES using a Single Multiple-Byte Fault, Cryptology ePrint Archive, vol.636, 2010. ,
Low Voltage Fault Attacks on the RSA Cryptosystem, 2009 Workshop on Fault Diagnosis and Tolerance in Cryptography (FDTC), pp.23-31 ,
DOI : 10.1109/FDTC.2009.30
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.472.3733
Differential fault analysis of secret key cryptosystems ,
DOI : 10.1007/BFb0052259
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.140.2571
Fault Based Cryptanalysis of the Advanced Encryption Standard (AES), Lecture Notes in Computer Science, vol.2742, pp.162-181, 2003. ,
DOI : 10.1007/978-3-540-45126-6_12
On the Importance of Checking Cryptographic Protocols for Faults (Extended Abstract), EUROCRYPT, pp.37-51, 1997. ,
Differential Fault Analysis on AES Key Schedule and Some Coutnermeasures, ACISP, pp.118-129, 2003. ,
DOI : 10.1007/3-540-45067-x_11
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.532.7706
DFA on AES, AES Conference, pp.27-41, 2004. ,
DOI : 10.1007/11506447_4
Differential Fault Analysis on A.E.S, E.S. Cryptology ePrint Archive, 2003. ,
DOI : 10.1007/978-3-540-45203-4_23
Practical Fault Attack on a Cryptographic LSI with ISO/IEC 18033-3 Block Ciphers, 2009 Workshop on Fault Diagnosis and Tolerance in Cryptography (FDTC), pp.84-92 ,
DOI : 10.1109/FDTC.2009.34
New Differential Fault Analysis on AES Key Schedule: Two Faults Are Enough, CARDIS, pp.48-60, 2008. ,
A Generalized Method of Differential Fault Attack Against AES Cryptosystem, CHES, pp.91-100, 2006. ,
DOI : 10.1007/11894063_8
An Improved Fault Based Attack of the Advanced Encryption Standard, Lecture Notes in Computer Science, vol.5580, pp.421-434, 2009. ,
DOI : 10.1109/FDTC.2007.13
A DFA attack against the AES key schedule. SiVenture White Paper 001, 2006. ,
A Differential Fault Attack Technique against SPN Structures, with Application to the AES and Khazad ,
DOI : 10.1007/978-3-540-45238-6_7
Practical Setup Time Violation Attacks on AES, 2008 Seventh European Dependable Computing Conference, pp.91-96, 2008. ,
DOI : 10.1109/EDCC-7.2008.11
Optical Fault Induction Attacks, CHES, pp.2-12, 2002. ,
DFA Mechanism on the AES Key Schedule, Workshop on Fault Diagnosis and Tolerance in Cryptography (FDTC 2007), pp.62-74, 2007. ,
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.124.9785
Differential Fault Analysis of the Advanced Encryption Standard Using a Single Fault, Cryptology ePrint Archive Report, vol.575, 2009. ,
DOI : 10.1007/978-3-642-21040-2_15
URL : https://hal.archives-ouvertes.fr/hal-01573310
Differential Fault Analysis of the Advanced Encryption Standard Using a Single Fault, WISTP, pp.224-233, 2011. ,
