New interface
Journal articles
Surface reconstruction by computing restricted Voronoi cells in parallel
Dobrina Boltcheva 1 Bruno Levy 1
1 ALICE - Geometry and Lighting
Inria Nancy - Grand Est, LORIA - ALGO - Department of Algorithms, Computation, Image and Geometry
Abstract : We present a method for reconstructing a 3D surface triangulation from an input point set. The main component of the method is an algorithm that computes the restricted Voronoi diagram. In our specific case, it corresponds to the intersection between the 3D Voronoi diagram of the input points and a set of disks centered at the points and orthogonal to the estimated normal directions. The method does not require coherent normal orientations (just directions). Our algorithm is based on a property of the restricted Voronoi cells that leads to an embarrassingly parallel implementation. We experimented our algorithm with scanned point sets with up to 100 million vertices that were processed within few minutes on a standard computer. The complete implementation is provided.
Document type :
Journal articles
Complete list of metadata
Cited literature [47 references]  Display  Hide  Download
https://hal.inria.fr/hal-01596553
Contributor : Dobrina Boltcheva Connect in order to contact the contributor
Submitted on : Thursday, September 28, 2017 - 10:04:09 AM
Last modification on : Friday, July 8, 2022 - 10:06:47 AM
Long-term archiving on: : Friday, December 29, 2017 - 12:23:49 PM
File
CAD17.pdf
Identifiers
Collections
Citation
Dobrina Boltcheva, Bruno Levy. Surface reconstruction by computing restricted Voronoi cells in parallel. Computer-Aided Design, 2017, 90, pp.123 - 134. ⟨10.1016/j.cad.2017.05.011⟩. ⟨hal-01596553⟩
Share
Metrics
Record views
563
Files downloads
818
