The Application of Preference Mapping in Aesthetic Website Evaluation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Eleftherios Papachristos
  • Fonction : Auteur
  • PersonId : 1004939
Nikolaos Avouris
  • Fonction : Auteur
  • PersonId : 1016828
The objective of this study was to apply a technique called preference mapping to the context of aesthetic website evaluation. Preference mapping is a method in which evaluators and stimuli are simultaneously represented in the same multidimensional space. User segmentations and drivers of preference can easily be identified. We argue that this technique is particularly suited for website design evaluation especially for alternative prototype comparisons. The application of this method to an actual dataset resulted in a better understanding of participant preferences that could not be reached through simple comparison of average ratings.
978-3-642-23768-3_96_Chapter.pdf (121.76 Ko) Télécharger le fichier
hal-01596932 , version 1 (28-09-2017)
Paternité
Eleftherios Papachristos, Nikolaos Avouris. The Application of Preference Mapping in Aesthetic Website Evaluation. 13th International Conference on Human-Computer Interaction (INTERACT), Sep 2011, Lisbon, Portugal. pp.616-619, ⟨10.1007/978-3-642-23768-3_96⟩. ⟨hal-01596932⟩
48 Consultations
62 Téléchargements
