Swept volume parametrization for isogeometric analysis, The Mathematics of Surfaces, pp.19-44, 2009. ,
DOI : 10.1007/978-3-642-03596-8_2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.212.8875
Nonlocal and surface effects on the buckling behavior of functionally graded nanoplates: An isogeometric analysis, Physica E: Low-dimensional Systems and Nanostructures, pp.84-97, 2016. ,
DOI : 10.1016/j.physe.2016.05.036
Isogeometric finite element data structures based on B??zier extraction of NURBS, International Journal for Numerical Methods in Engineering, vol.199, issue.3, pp.1-5, 2011. ,
DOI : 10.1016/j.cma.2008.12.004
Adaptively refined multi-patch B-splines with enhanced smoothness, Applied Mathematics and Computation, vol.272, pp.159-172, 2016. ,
DOI : 10.1016/j.amc.2015.06.055
Planar multi-patch domain parameterization via patch adjacency graphs, Computer-Aided Design, vol.82, pp.2-12, 2017. ,
DOI : 10.1016/j.cad.2016.05.019
Differential geometry of curves and surfaces, 1976. ,
Volumetric parametrization from a level set boundary representation with PHT-splines, Computer-Aided Design, vol.82, pp.29-41, 2017. ,
DOI : 10.1016/j.cad.2016.08.008
Analysis-aware modeling: Understanding quality considerations in modeling for isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.334-356, 2010. ,
DOI : 10.1016/j.cma.2009.09.010
Isogeometric Analysis: Toward Integration of CAD and FEA, 2009. ,
DOI : 10.1002/9780470749081
Studies of refinement and continuity in isogeometric structural analysis, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.41-44, pp.4160-4183, 2007. ,
DOI : 10.1016/j.cma.2007.04.007
On the classical logarithmic barrier function method for a class of smooth convex programming problems, Journal of Optimization Theory and Applications, vol.19, issue.1, pp.1-25, 1992. ,
DOI : 10.1007/BFb0083587
A new approach to solid modeling with trivariate T-splines based on mesh optimization, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.45-46, pp.200-3210, 2011. ,
DOI : 10.1016/j.cma.2011.07.004
Planar domain parameterization with THB-splines, Computer Aided Geometric Design, vol.35, issue.36, pp.35-36, 2015. ,
DOI : 10.1016/j.cagd.2015.03.014
Planar Parametrization in Isogeometric Analysis, Lecture Notes in Computer Science, vol.8177, pp.189-212, 2014. ,
DOI : 10.1007/978-3-642-54382-1_11
URL : http://orbit.dtu.dk/files/127276933/OsloPaper.pdf
Matched <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:msup><mml:mrow><mml:mi>G</mml:mi></mml:mrow><mml:mrow><mml:mi>k</mml:mi></mml:mrow></mml:msup></mml:math>-constructions always yield <mml:math altimg="si2.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:msup><mml:mrow><mml:mi>C</mml:mi></mml:mrow><mml:mrow><mml:mi>k</mml:mi></mml:mrow></mml:msup></mml:math>-continuous isogeometric elements, Computer Aided Geometric Design, vol.34, pp.67-72, 2015. ,
DOI : 10.1016/j.cagd.2015.02.002
Curves and Surfaces for CAGD -A Practical Guide, 2002. ,
A geometric constraint on curve networks suitable for smooth interpolation, Computer-Aided Design, vol.43, issue.7, pp.43-741, 2011. ,
DOI : 10.1016/j.cad.2010.05.007
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry and mesh refinement, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.39-41, pp.4135-4195, 2005. ,
DOI : 10.1016/j.cma.2004.10.008
URL : https://hal.archives-ouvertes.fr/hal-01513346
Isogeometric analysis with geometrically continuous functions on two-patch geometries, Computers & Mathematics with Applications, vol.70, issue.7, pp.1518-1538, 2015. ,
DOI : 10.1016/j.camwa.2015.04.004
Isogeometric analysis with geometrically continuous functions on planar multi-patch geometries, Computer Methods in Applied Mechanics and Engineering, vol.316, pp.316-209, 2017. ,
DOI : 10.1016/j.cma.2016.06.002
Refinable G 1 functions on G 1 free-form surfaces, Computer Aided Geometric Design, vol.54, pp.61-73, 2017. ,
DOI : 10.1016/j.cagd.2017.02.014
Generalizing bicubic splines for modeling and IGA with irregular layout, Computer-Aided Design, vol.70, pp.23-35, 2016. ,
DOI : 10.1016/j.cad.2015.07.014
Approximate convex decomposition of polygons, Computational Geometry, vol.35, issue.1-2, pp.100-123, 2016. ,
DOI : 10.1016/j.comgeo.2005.10.005
URL : http://doi.org/10.1016/j.comgeo.2005.10.005
Volumetric T-spline construction using Boolean operations, Engineering with Computers, vol.249, issue.252, pp.425-439, 2014. ,
DOI : 10.1016/j.cma.2012.01.014
AUTOMESH???2D/3D: robust automatic mesh generator for metal forming simulation, Materials Research Innovations, vol.15, issue.sup1, pp.482-486, 2011. ,
DOI : 10.1016/j.cad.2007.05.016
Volumetric parameterization and trivariate B-spline fitting using harmonic functions, Computer Aided Geometric Design, vol.26, issue.6, pp.648-664, 2009. ,
DOI : 10.1016/j.cagd.2008.09.008
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.140.2120
Dimension and bases for geometrically continuous splines on surfaces of arbitrary topology, Computer Aided Geometric Design, vol.45, pp.108-133, 2016. ,
DOI : 10.1016/j.cagd.2016.03.003
Sharp, quantitative bounds on the distance between a polynomial piece and its B??zier control polygon, Computer Aided Geometric Design, vol.16, issue.7, pp.613-631, 1999. ,
DOI : 10.1016/S0167-8396(99)00026-6
Parameterization of Contractible Domains Using Sequences of Harmonic Maps, Lecture Notes in Computer Science, vol.200, issue.23-24, pp.501-514, 2012. ,
DOI : 10.1016/j.cma.2011.03.005
Isogeometric analysis suitable trivariate NURBS representation of composite panels with a new offset algorithm, Computer-Aided Design, vol.55, pp.49-63, 2014. ,
DOI : 10.1016/j.cad.2014.05.004
Planar domain parameterization for isogeometric analysis based on Teichm??ller mapping, Computer Methods in Applied Mechanics and Engineering, vol.311, pp.41-55, 2016. ,
DOI : 10.1016/j.cma.2016.07.035
Numerical Optimization, Series in Operations Research and Financial Engineering, 2006. ,
DOI : 10.1007/b98874
Isogeometric analysis of large-deformation thin shells using RHT-splines for multiple-patch coupling, Computer Methods in Applied Mechanics and Engineering, vol.316, pp.316-1157, 2017. ,
DOI : 10.1016/j.cma.2016.12.002
An adaptive threedimensional RHT-spline formulation in linear elasto-statics and elasto-dynamics, Computational Mechanics, pp.53-369, 2014. ,
DOI : 10.1007/s00466-013-0914-z
Rotation free isogeometric thin shell analysis using PHT-splines, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.47-48, pp.200-3410, 2011. ,
DOI : 10.1016/j.cma.2011.08.014
Isogeometric analysis using polynomial splines over hierarchical T-meshes for two-dimensional elastic solids, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.21-22, pp.200-1892, 2011. ,
DOI : 10.1016/j.cma.2011.01.018
Bounding the influence of domain parameterization and knot spacing on numerical stability in Isogeometric Analysis, Computer Methods in Applied Mechanics and Engineering, vol.268, pp.589-613, 2014. ,
DOI : 10.1016/j.cma.2013.09.019
Isogeometric finite element approximation of minimal surfaces based on extended loop subdivision, Journal of Computational Physics, vol.343, pp.1-16, 2017. ,
DOI : 10.1016/j.jcp.2017.04.030
Isogeometric analysis based on extended Loop's subdivision, Journal of Computational Physics, vol.299, pp.299-731, 2015. ,
DOI : 10.1016/j.jcp.2015.06.044
Spline Volume Fairing, Lecture Notes in Computer Science, vol.8, pp.553-561, 2012. ,
DOI : 10.1016/0167-8396(91)90004-U
A log-barrier method for mesh quality improvement and untangling, Engineering with Computers, vol.2, issue.4, pp.315-329, 2014. ,
DOI : 10.1137/0802028
Optimizing domain parameterization in isogeometric analysis based on Powell???Sabin splines, Journal of Computational and Applied Mathematics, vol.289, pp.68-86, 2015. ,
DOI : 10.1016/j.cam.2015.03.024
-Sided Patches, Computer Graphics Forum, vol.19, issue.6, pp.177-184, 2014. ,
DOI : 10.1016/j.cad.2012.10.041
URL : https://hal.archives-ouvertes.fr/pasteur-01402741
Subdivision method for finding the intersection between two Bézier curves or surfaces, Journal of Zhejiang University, Special Issue on Computational Geometry, pp.108-119, 1984. ,
Trivariate solid T-spline construction from boundary triangulations with arbitrary genus topology, Computer-Aided Design, vol.45, issue.2, pp.351-360, 2013. ,
DOI : 10.1016/j.cad.2012.10.018
An optimization approach for constructing trivariate -spline solids, Computer-Aided Design, vol.46, pp.179-191, 2014. ,
DOI : 10.1016/j.cad.2013.08.030
Isogeometric computation reuse method for complex objects with topology-consistent volumetric parameterization, Computer-Aided Design, vol.91, pp.1-13, 2017. ,
DOI : 10.1016/j.cad.2017.04.002
URL : http://arxiv.org/abs/1606.02959
Optimal analysis-aware parameterization of computational domain in 3D isogeometric analysis, Computer-Aided Design, vol.45, issue.4, pp.812-821, 2013. ,
DOI : 10.1016/j.cad.2011.05.007
URL : https://hal.archives-ouvertes.fr/inria-00539616
Parameterization of computational domain in isogeometric analysis: Methods and comparison, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.23-24, pp.2021-2031, 2011. ,
Analysis-suitable volume parameterization of multi-block computational domain in isogeometric applications, Computer-Aided Design, vol.45, issue.2, pp.395-404, 2013. ,
DOI : 10.1016/j.cad.2012.10.022
URL : https://hal.archives-ouvertes.fr/hal-00685002
Constructing analysis-suitable parameterization of computational domain from CAD boundary by variational harmonic method, Journal of Computational Physics, vol.252, pp.275-289, 2013. ,
DOI : 10.1016/j.jcp.2013.06.029
URL : https://hal.archives-ouvertes.fr/inria-00585663
High-quality construction of analysis-suitable trivariate NURBS solids by reparameterization methods, Computational Mechanics, vol.231, issue.47???48, pp.1303-1313, 2014. ,
DOI : 10.1016/j.jcp.2012.04.043
URL : https://hal.archives-ouvertes.fr/hal-00922544
Two-dimensional domain decomposition based on skeleton computation for parameterization and isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.284, pp.541-555, 2015. ,
DOI : 10.1016/j.cma.2014.09.026
Solid T-spline construction from boundary representations for genus-zero geometry, Computer Methods in Applied Mechanics and Engineering, vol.249, issue.252, pp.185-197, 2012. ,
URL : http://www.dtic.mil/get-tr-doc/pdf?AD=ADA555389
Conformal solid T-spline construction from boundary T-spline representations, Computational Mechanics, vol.196, issue.29???30, pp.1051-1059, 2013. ,
