Abstract : Online surveys are an important means of data collection in marketing and research, but conventional survey designs are often perceived as dull and unengaging, resulting in negative respondent behavior. Gamification has been proposed to make online surveys more pleasant to fill and, consequently, to improve the quality of survey results. This work applied gamification to an existing survey targeted at teenagers and young adults. The gamified survey was evaluated in a study with 60 participants regarding the psychological and behavioral outcomes of gamification. Results indicate that gamification successfully increased the users’ perceived fun, the average time spent, as well as their willingness to use and recommend the survey, without introducing a strong bias in survey results, albeit with a lower overall response rate.
https://hal.inria.fr/hal-01599660 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, October 2, 2017 - 1:13:43 PM Last modification on : Wednesday, October 13, 2021 - 7:58:04 PM
Johannes Harms, Stefan Biegler, Christoph Wimmer, Karin Kappel, Thomas Grechenig. Gamification of Online Surveys: Design Process, Case Study, and Evaluation. 15th Human-Computer Interaction (INTERACT), Sep 2015, Bamberg, Germany. pp.219-236, ⟨10.1007/978-3-319-22701-6_16⟩. ⟨hal-01599660⟩
