Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : In this work, we investigate gaze selection in the context of mid-air hand gestural manipulation of 3D rigid bodies on monoscopic displays. We present the results of a user study with 12 participants in which we compared the performance of Gaze, a Raycasting technique (2D Cursor) and a Virtual Hand technique (3D Cursor) to select objects in two 3D mid-air interaction tasks. Also, we compared selection confirmation times for Gaze selection when selection is followed by manipulation to when it is not. Our results show that gaze selection is faster and more preferred than 2D and 3D mid-air-controlled cursors, and is particularly well suited for tasks in which users constantly switch between several objects during the manipulation. Further, selection confirmation times are longer when selection is followed by manipulation than when it is not.
https://hal.inria.fr/hal-01599875 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, October 2, 2017 - 3:41:55 PM Last modification on : Tuesday, May 25, 2021 - 12:36:02 PM
Eduardo Velloso, Jayson Turner, Jason Alexander, Andreas Bulling, Hans Gellersen. An Empirical Investigation of Gaze Selection in Mid-Air Gestural 3D Manipulation. 15th Human-Computer Interaction (INTERACT), Sep 2015, Bamberg, Germany. pp.315-330, ⟨10.1007/978-3-319-22668-2_25⟩. ⟨hal-01599875⟩
