Control of reproduction in northern pike - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1978
Several methods to control gamete availability in northern pike were investigated. Precocious induction of ovulation was achieved with a single injection of partially purified salmon gonadotropin, but the treatment should be administered soon after capture in order to avoid ovarian atresia. Ovulated oocytes should be inseminated within 24 hours after ovulation. Loss of fertility due to aging occurred 1-3 days after ovulation. High doses of progesterone induced a threefold increase of sperm release. Cryopreservation of diluted sperm at -196 C led to variable fertilizing capacities after thawing, depending on the donor male. A diluent originally tested for trout was used successfully for artificial insemination.
Mont1978Fish_1.pdf (696.79 Ko) Télécharger le fichier
hal-01600874 , version 1 (04-06-2020)
Paternité - Partage selon les Conditions Initiales
  • HAL Id : hal-01600874 , version 1
  • PRODINRA : 394597
G. de Montalembert, Christian Bry, Roland Billard. Control of reproduction in northern pike. Symposium on Selected Coolwater Fishes of North America, American Fisheries Society (AFS). USA., Mar 1978, Saint-Paul, Minnesota, United States. ⟨hal-01600874⟩
Collections
INRA LPGP INRAE
104 Consultations
17 Téléchargements
