Weaving Rules into Models@run.time for Embedded Smart Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Smart systems are characterised by their ability to analyse measured data in live and to react to changes according to expert rules. Therefore, such systems exploit appropriate data models together with actions, triggered by domain-related conditions. The challenge at hand is that smart systems usually need to process thousands of updates to detect which rules need to be triggered, often even on restricted hardware like a Raspberry Pi. Despite various approaches have been investigated to efficiently check conditions on data models, they either assume to fit into main memory or rely on high latency persistence storage systems that severely damage the reactivity of smart systems. To tackle this challenge, we propose a novel composition process, which weaves executable rules into a data model with lazy loading abilities. We quantitatively show, on a smart building case study, that our approach can handle, at low latency, big sets of rules on top of large-scale data models on restricted hardware.
main.pdf (535.32 Ko) Télécharger le fichier
hal-01609796 , version 1 (04-10-2017)
Ludovic Mouline, Thomas Hartmann, François Fouquet, Yves Le Traon, Johann Bourcier, et al.. Weaving Rules into Models@run.time for Embedded Smart Systems. Programming 2017 - Companion to the first International Conference on the Art, Science and Engineering of Programming, Apr 2017, Brussels, Belgium. pp.1 - 6, ⟨10.1145/3079368.3079394⟩. ⟨hal-01609796⟩
390 Consultations
147 Téléchargements
