WhichFingers: Identifying Fingers on Touch Surfaces and Keyboards using Vibration Sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
HCI researchers lack low-latency and robust systems to support the design and development of interaction techniques using finger identification. We developed a low-cost prototype using piezo-based vibration sensors attached to each finger. By combining the events from an input device with the information from the vibration sensors we demonstrate how to achieve low-latency and robust finger identification. Our prototype was evaluated in a controlled experiment, using two keyboards and a touchpad, showing single-touch recognition rates of 98.2% for the keyboard and 99.7% for the touch-pad, and 94.7% for two simultaneous touches. These results were confirmed in an additional laboratory-style experiment with ecologically valid tasks. Last we present new interaction techniques made possible using this technology.
paper.pdf (1.68 Mo) Télécharger le fichier
hal-01609943 , version 1 (04-10-2017)
Damien Masson, Alix Goguey, Sylvain Malacria, Géry Casiez. WhichFingers: Identifying Fingers on Touch Surfaces and Keyboards using Vibration Sensors. UIST 2017 - 30th ACM Symposium on User Interface Software and Technology, Oct 2017, Québec, Canada. pp.8, ⟨10.1145/3126594.3126619⟩. ⟨hal-01609943⟩
392 Consultations
1338 Téléchargements
