Automatic parallelization of multi-rate fmi-based co-simulation on multi-core
Co-simulation refers to simulating a complex system using several coupled numerical models. Engineers
define the rate of data exchange between the models by setting communication steps. FMI is a standardized
interface which easily allows coupling and co-simulation of numerical models. The RCOSIM approach
allows the parallelization on multi-core processors of co-simulations using the FMI standard. In this paper,
we tackle the limitations of this approach. First, we extend the co-simulation to multi-rate, i.e. with different
communication steps. We present graph transformation rules and an algorithm that allow the execution of
each model at its respective rate while ensuring correct data exchange between models. Second, we present
an acyclic orientation heuristic for handling mutual exclusion constraints between operations that belong to
the same model due to the non-thread-safe implementation of FMI. We evaluate the obtained speedup on a
multi-core processor and the effect on the accuracy of the numerical results.
Domains
Computer Science [cs] Distributed, Parallel, and Cluster Computing [cs.DC] Computer Science [cs] Embedded Systems Computer Science [cs] Modeling and Simulation Computer Science [cs] Operating Systems [cs.OS] Computer Science [cs] Operations Research [cs.RO] Computer Science [cs] Systems and Control [cs.SY] Computer Science [cs] Software Engineering [cs.SE]
