On the benefits of successive interference cancellation for ultra narrow band networks : Theory and application to IoT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
UNB (Ultra Narrow Band) stands out as one promising PHY solution for low-power, low-throughput and long-range IoT. The dedicated MAC scheme is RFTMA (Random Frequency and Time Multiple Access), where nodes access the channel randomly both in frequency and in time domain, without prior channel sensing. This blind randomness sometimes introduces interference and packet losses. Hence, in this paper, we propose to use the well-known SIC (Successive Interference Cancellation) to cancel the interference in a recursive way. We provide a theoretical analysis of network performance, when considering jointly SIC and the specific spectral randomness of UNB. We analytically and numerically highlight the SIC efficiency in enhancing UNB system performance.
2017-05-ICC-On the Benefits of Successive Interference Cancellation for Ultra Narrow Band Networks Theory and Application to IoT.pdf (1.12 Mo) Télécharger le fichier
hal-01610465 , version 1 (04-10-2017)
Yuqi Mo, Claire Goursaud, Jean-Marie Gorce. On the benefits of successive interference cancellation for ultra narrow band networks : Theory and application to IoT. IEEE ICC 2017 - IEEE International Conference on Communications, May 2017, Paris, France. pp.1 - 6, ⟨10.1109/ICC.2017.7996900⟩. ⟨hal-01610465⟩
101 Consultations
631 Téléchargements
