Human Work Interaction Design (HWID): Design for Challenging Work Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pedro Campos
  • Fonction : Auteur
  • PersonId : 1018008
Frederica Gonçalves
  • Fonction : Auteur
  • PersonId : 989520
Verena Fuchsberger
  • Fonction : Auteur
  • PersonId : 989525
Martin Murer
  • Fonction : Auteur
  • PersonId : 1011765
Manfred Tscheligi
  • Fonction : Auteur
  • PersonId : 989546
José Abdelnour-Nocera
  • Fonction : Auteur
  • PersonId : 989551
This one-day workshop aims to contribute to the goals of the IFIP 13.6 Human Work Interaction Design (HWID) working group, i.e., to establish relationships between empirical work-domain studies and recent developments in interaction design. This goal translates to the workshop by focusing on work environments that are challenging for research and design; from physically or spatially unusual workplaces (e.g., oil platforms), mentally demanding or specifically boring work (e.g., control rooms, academics) to challenging social situations at work (e.g., in hospitals). The workshop aims to discuss resulting constraints for research and design, e.g., restricted access for research, or difficulties in articulating the specifics of the workplaces to a wider audience that is not familiar with them. Some work environments may even impede forms of design research, e.g., critical or provocative design will be hard to carry out in safety- or efficiency-critical workplaces. Thus, ways to generate knowledge addressing the design of interactive artifacts for challenging workplaces will be discussed.
346948_1_En_89_Chapter.pdf (97.43 Ko) Télécharger le fichier
hal-01610800 , version 1 (05-10-2017)
Paternité
Pedro Campos, Frederica Gonçalves, Barbara Rita Barricelli, Verena Fuchsberger, Martin Murer, et al.. Human Work Interaction Design (HWID): Design for Challenging Work Environments. 15th Human-Computer Interaction (INTERACT), Sep 2015, Bamberg, Germany. pp.659-660, ⟨10.1007/978-3-319-22723-8_89⟩. ⟨hal-01610800⟩
79 Consultations
87 Téléchargements
