Cooperation in Real-Time Using a Virtual Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Effective team interaction over great distances are already supported by many digital tools. However, cooperative manipulation of common objects is limited and most non-verbal information (gaze direction, facial expressions) can be transmitted only partially or are missing completely. The inclusion of these additional information sources can enrich cooperative problems solving situations. In our demonstration we highlight the capabilities of the Virtual Collaboration Arena to support such interactions. With the help of a volunteer from the audience in Bamberg we will present parts of an information management task solved cooperatively with another user seated in Budapest.
346948_1_En_38_Chapter.pdf (192.39 Ko) Télécharger le fichier
hal-01610859 , version 1 (05-10-2017)
Paternité
Máté Köles, Károly Hercegfi, Balázs Péter Hámornik, Emma Lógó, Bálint Szabó, et al.. Cooperation in Real-Time Using a Virtual Environment. 15th Human-Computer Interaction (INTERACT), Sep 2015, Bamberg, Germany. pp.461-464, ⟨10.1007/978-3-319-22723-8_38⟩. ⟨hal-01610859⟩
41 Consultations
67 Téléchargements
