Why can’t users choose their identity providers on the web? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings on Privacy Enhancing Technologies Année : 2017
Authentication delegation is a major function of the modern web. Identity Providers (IdP) acquired a central role by providing this function to other web services. By knowing which web services or web applications access its service, an IdP can violate the end-user privacy by discovering information that the user did not want to share with its IdP. For instance, WebRTC introduces a new field of usage as authentication delegation happens during the call session establishment, between two users. As a result, an IdP can easily discover that Bob has a meeting with Alice. A second issue that increases the privacy violation is the lack of choice for the end-user to select its own IdP. Indeed, on many web-applications, the end-user can only select between a subset of IdPs, in most cases Facebook or Google. In this paper, we analyze this phenomena, in particular why the end-user cannot easily select its preferred IdP, though there exists standards in this field such as OpenID Connect and OAuth 2? To lead this analysis, we conduct three investigations. The first one is a field survey on OAuth 2 and OpenID Connect scope usage by web sites to understand if scopes requested by web-sites could allow for user defined IdPs. The second one tries to understand whether the problem comes from the OAuth 2 protocol or its implementations by IdP. The last one tries to understand if trust relations between websites and IdP could prevent the end user to select its own IdP. Finally, we sketch possible architecture for web browser based identity management, and report on the implementation of a prototype.
Web
main.pdf (660 Ko) Télécharger le fichier
hal-01611048 , version 1 (05-10-2017)
Kevin Corre, Olivier Barais, Gerson Sunyé, Vincent Frey, Jean-Michel Crom. Why can’t users choose their identity providers on the web?. Proceedings on Privacy Enhancing Technologies, 2017, 2017 (3), pp.72-86. ⟨10.1515/popets-2017-0029⟩. ⟨hal-01611048⟩
539 Consultations
327 Téléchargements
