New interface
Journal articles
Computing metric hulls in graphs
Kolja Knauer 1 Nicolas Nisse 2
2 COATI - Combinatorics, Optimization and Algorithms for Telecommunications
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : We prove that, given a closure function the smallest preimage of a closed set can be calculated in polynomial time in the number of closed sets. This implies that there is a polynomial time algorithm to compute the convex hull number of a graph, when all its convex subgraphs are given as input. We then show that deciding if the smallest preimage of a closed set is logarithmic in the size of the ground set is LOGSNP-hard if only the ground set is given. A special instance of this problem is to compute the dimension of a poset given its linear extension graph, that is conjectured to be in P. The intent to show that the latter problem is LOGSNP-complete leads to several interesting questions and to the definition of the isometric hull, i.e., a smallest isometric subgraph containing a given set of vertices $S$. While for $|S|=2$ an isometric hull is just a shortest path, we show that computing the isometric hull of a set of vertices is NP-complete even if $|S|=3$. Finally, we consider the problem of computing the isometric hull number of a graph and show that computing it is $\Sigma^P_2$ complete.
Document type :
Journal articles
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/hal-01612515
Contributor : Nicolas Nisse Connect in order to contact the contributor
Submitted on : Thursday, May 23, 2019 - 1:32:32 PM
Last modification on : Thursday, August 4, 2022 - 4:58:26 PM
File
DMTCS_MetricHull_Final.pdf
Identifiers
Citation
Kolja Knauer, Nicolas Nisse. Computing metric hulls in graphs. Discrete Mathematics and Theoretical Computer Science, 2019, vol. 21 no. 1, ICGT 2018, ⟨10.23638/DMTCS-21-1-11⟩. ⟨hal-01612515v4⟩
Share
Metrics
Record views
521
Files downloads
851
