Anomaly Prevision in Radio Access Networks Using Functional Data Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In order to help the network maintainers with the daily diagnosis and optimization tasks, a supervised model for mobile anomalies prevention is proposed. The objective is to detect future malfunctions of a set of cells, by only observing key performance indicators that are considered as functional data. Thus, by alerting the engineers as well as self-organizing networks, mobile operators can be saved from a certain performance degradation. The model has proven its efficiency with an application on real data that aims to detect capacity degradation, accessibility and call drops anomalies for LTE networks.
anomaly_prevision.pdf (3.44 Mo) Télécharger le fichier
hal-01613475 , version 1 (09-10-2017)
  • HAL Id : hal-01613475 , version 1
Yosra Ben Slimen, Sylvain Allio, Julien Jacques. Anomaly Prevision in Radio Access Networks Using Functional Data Analysis. IEEE GlobeCom 2017, Dec 2017, Singapour, Singapore. ⟨hal-01613475⟩
107 Consultations
439 Téléchargements
