Fitness landscape based features for exploiting black-box optimization problem structure, 2012. ,
Mvf-multivariate test functions library in c for unconstrained global optimization, 2005. ,
Parameter tuned CMA-ES on the CEC'15 expensive problems, 2015 IEEE Congress on Evolutionary Computation (CEC), pp.1950-1957, 2015. ,
DOI : 10.1109/CEC.2015.7257124
Sequential Parameter Optimization, 2005 IEEE Congress on Evolutionary Computation, pp.773-780, 2005. ,
DOI : 10.1109/CEC.2005.1554761
Feature Based Algorithm Configuration: A Case Study with Differential Evolution, International Conference on Parallel Problem Solving from Nature, pp.156-166, 2016. ,
DOI : 10.1109/4235.585893
URL : https://hal.archives-ouvertes.fr/hal-01359539
Surrogate Assisted Feature Computation for Continuous Problems, International Conference on Learning and Intelligent Optimization, pp.17-31, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01303320
A Racing Algorithm for Configuring Metaheuristics, GECCO, pp.11-18, 2002. ,
Learning Feature-Parameter Mappings for Parameter Tuning via the Profile Expected Improvement, Proceedings of the 2015 on Genetic and Evolutionary Computation Conference, GECCO '15, pp.1319-1326, 2015. ,
DOI : 10.1162/EVCO_a_00061
Benchmarking a BI-population CMA-ES on the BBOB-2009 function testbed, Proceedings of the 11th annual conference companion on Genetic and evolutionary computation conference, GECCO '09, pp.2389-2396, 2009. ,
DOI : 10.1145/1570256.1570333
URL : https://hal.archives-ouvertes.fr/inria-00382093
Real- Parameter Black-Box Optimization Benchmarking 2010: Experimental Setup, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00462481
Completely Derandomized Self-Adaptation in Evolution Strategies, Evolutionary Computation, vol.9, issue.2, pp.159-195, 2001. ,
DOI : 10.1016/0004-3702(95)00124-7
Impacts of invariance in search: When CMA-ES and PSO face ill-conditioned and non-separable problems, Applied Soft Computing, vol.11, issue.8, pp.5755-5769, 2011. ,
DOI : 10.1016/j.asoc.2011.03.001
URL : https://hal.archives-ouvertes.fr/inria-00583669
Test examples for nonlinear programming codes, Journal of Optimization Theory and Applications, vol.30, issue.1, pp.127-129, 1980. ,
DOI : 10.1007/BF00934594
Programming by optimization, Comm. of the ACM, vol.55, issue.2, pp.70-80, 2012. ,
Performance Prediction and Automated Tuning of Randomized and Parametric Algorithms, Intl Conf. on Principles and Practice of Constraint Programming, pp.213-228, 2006. ,
DOI : 10.1007/11889205_17
Sequential modelbased optimization for general algorithm configuration, Proc. LION 5, pp.507-523, 2011. ,
ParamILS: an automatic algorithm configuration framework, Journal of Artificial Intelligence Research, vol.36, issue.1, pp.267-306, 2009. ,
Algorithm runtime prediction: Methods & evaluation, Artificial Intelligence, vol.206, pp.79-111, 2014. ,
DOI : 10.1016/j.artint.2013.10.003
ISAC -Instance-Specific Algorithm Configuration, In ECAI, vol.215, pp.751-756, 2010. ,
Lowbudget exploratory landscape analysis on multiple peaks models, Proceedings of the 2016 on Genetic and Evolutionary Computation Conference, pp.229-236, 2016. ,
Learning the Empirical Hardness of Optimization Problems: The Case of Combinatorial Auctions, Principles and Practice of Constraint Programming-CP 2002, pp.556-572, 2002. ,
DOI : 10.1007/3-540-46135-3_37
Maximum Likelihood-Based Online Adaptation of Hyper-Parameters in CMA-ES, 2014. ,
DOI : 10.1007/978-3-319-10762-2_7
URL : https://hal.archives-ouvertes.fr/hal-01003504
The dispersion metric and the CMA evolution strategy, Proceedings of the 8th annual conference on Genetic and evolutionary computation , GECCO '06, pp.477-484, 2006. ,
DOI : 10.1145/1143997.1144085
Exploratory landscape analysis, Proceedings of the 13th annual conference on Genetic and evolutionary computation, GECCO '11, pp.829-836, 2011. ,
DOI : 10.1145/2001576.2001690
Exploratory Landscape Analysis of Continuous Space Optimization Problems Using Information Content, IEEE Transactions on Evolutionary Computation, vol.19, issue.1, pp.74-87, 2015. ,
DOI : 10.1109/TEVC.2014.2302006
A meta-learning prediction model of algorithm performance for continuous optimization problems, PPSN XII, pp.226-235, 2012. ,
Efficient relevance estimation and value calibration of evolutionary algorithm parameters, 2007 IEEE Congress on Evolutionary Computation, pp.6-12, 2007. ,
DOI : 10.1109/CEC.2007.4424460
More test examples for nonlinear programming codes. More test examples for nonlinear programming codes, 1987. ,
Differential evolution?a simple and efficient heuristic for global optimization over continuous spaces, Journal of Global Optimization, vol.11, issue.4, pp.341-359, 1997. ,
DOI : 10.1023/A:1008202821328
No free lunch theorems for optimization, IEEE Transactions on Evolutionary Computation, vol.1, issue.1, pp.67-82, 1997. ,
Hydra, Proceedings of the 2005 ACM workshop on Storage security and survivability , StorageSS '05, pp.210-216, 2010. ,
DOI : 10.1145/1103780.1103797
SATzilla-07: The Design and Analysis of an Algorithm Portfolio for SAT, Intl Conf. on Principles and Practice of Constraint Programming, pp.712-727, 2007. ,
DOI : 10.1007/978-3-540-74970-7_50
SATzilla: portfolio-based algorithm selection for SAT, Journal of Artificial Intelligence Research, pp.565-606, 2008. ,
Hydra-MIP: Automated algorithm configuration and selection for mixed integer programming, RCRA workshop on experimental evaluation of algorithms for solving problems with combinatorial explosion at the international joint conference on artificial intelligence (IJCAI, pp.16-30, 2011. ,
