Abstract : Taking maize precise assignments section as the research object, using arcgis10.2 as the visual drive tool, comprehensive application of 3D modeling, database and GIS technology, this paper proposed a method of rapid establishment of agricultural areas of 3D virtual scene, developed soil moisture monitoring 3D simulation system based on GIS. The system had the 3D model search module, the dynamic scene simulation module, the dynamic monitoring and spatial information management function module and so on. Using Jilin Province Nong’an County town of Helong corn precision operation as an example, the system were preliminary application, the application results showed that the system can realize the effective management of agriculture areas, soil moisture spatial information and virtual display. According to the 3D model of soil moisture dynamic monitoring module, for the analysis and application of the regional soil moisture laid a solid foundation, and provided effective digital management platform for precision agriculture technique.
https://hal.inria.fr/hal-01614166 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, October 10, 2017 - 3:41:33 PM Last modification on : Tuesday, October 10, 2017 - 3:54:23 PM Long-term archiving on: : Thursday, January 11, 2018 - 1:29:02 PM
Guifen Chen, Jian Lu, ying Meng, Liying Cao, Li Ma. Research and Application of Monitoring and Simulating System of Soil Moisture Based on Three-Dimensional GIS. 9th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2015, Beijing, China. pp.100-110, ⟨10.1007/978-3-319-48354-2_10⟩. ⟨hal-01614166⟩
