A new modified fast fractal image compression algorithm, The Journal of Imaging Science, issue.2, pp.61219-231, 2013. ,
Fractal image compression: Theory and Applications, p.34, 1995. ,
An edge property-based neighborhood region search strategy for fractal image compression, Computers&Mathematics with Applications, pp.310-318, 2011. ,
DOI : 10.1016/j.camwa.2011.05.011
The effectiveness of image features based on fractal image coding for image annotation, Expert Systems with Applications, issue.17, pp.3912897-12904, 2012. ,
A study on fractal image compression using soft computing techniques, International Journal of Computer Science Issues, vol.2012, issue.96, pp.420-430 ,
Image coding based on a fractal theory of iterated contractive image transformations, IEEE Transactions on Image Processing, vol.1, issue.1, pp.18-30, 1992. ,
DOI : 10.1109/83.128028
Speeding up fractal image compression using DCT descriptors, Journal of Information and Computing Science, vol.6, issue.4, pp.287-294, 2011. ,
Image compression researchbased on fractal theory, 2012. ,
Fast encoding algorithm for fractal image compression, p.2013 ,
Fractal encoding compression method based on detail block of image, Chinese), pp.217-218, 2010. ,
A FAST FRACTAL CODING IN APPLICATION OF IMAGE RETRIEVAL, Fractals, vol.30, issue.04, pp.44-450, 2009. ,
DOI : 10.1109/83.679437
A novel fast fractal super resolution technique, IEEE Transactions on Consumer Electronics, vol.56, issue.3, pp.1537-1541, 2010. ,
DOI : 10.1109/TCE.2010.5606294
A noval method for embedding gray image watermarking into orthogonal fractal compression image, Proceedings of International Conference of Communications, Circuits and Systems, pp.485-488, 2009. ,
An improved fractal image compression algorithm, Chinese), pp.109-111, 2013. ,
