Abstract : With the characteristics of fast transferring speed and wide coverage of TD-LTE network, the research designs and implements the TD-LTE-based Real-time Monitoring System for Greenhouse Environment Temperature. The TD-LTE network, which is connected with the data server of the Internet, can transmit the real-time temperature data that sensor collects to the data server. The B/S mode-based data server can realize data query, analysis and other functions. This monitoring system solves the problems that previous monitoring systems are slow and can not be transmitted at a distance, and it can also meet the need of the real-time data acquisition that precision agriculture needs.
https://hal.inria.fr/hal-01614217 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, October 10, 2017 - 3:43:46 PM Last modification on : Wednesday, July 21, 2021 - 10:28:03 AM Long-term archiving on: : Thursday, January 11, 2018 - 2:09:47 PM
Xin Zhao, Yang Jiao, Lianjun Yu, Chuanhong Zhang. Design and Implementation of TD-LTE-Based Real-Time Monitoring System for Greenhouse Environment Temperature. 9th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2015, Beijing, China. pp.170-177, ⟨10.1007/978-3-319-48354-2_18⟩. ⟨hal-01614217⟩
