Research and Application on Protected Vegetables Early Warning and Control of Mobile Client System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Guogang Zhao
  • Fonction : Auteur
  • PersonId : 996648
Haiye Yu
  • Fonction : Auteur
  • PersonId : 996649
Lianjun Yu
  • Fonction : Auteur
  • PersonId : 1020421
Yuanyuan Sui
  • Fonction : Auteur
  • PersonId : 996651
Lei Zhang
  • Fonction : Auteur
  • PersonId : 996652
Linlin Wang
  • Fonction : Auteur
  • PersonId : 1020487
Jiao Yang
  • Fonction : Auteur
  • PersonId : 1020485
Experimental vegetable production is greatly influenced by many environmental factors. There is urgent need to supervise its air temperature and humidity, soil temperature and humidity in the facilities information such as real-time monitoring, and timely early warning and control, in case of irreparable damage. This paper adopts the IOT technology to design and develop mobile client system which is used to make warnings and protect vegetables in order to realize real-time monitoring in the process of vegetable production in the aspects of timely warning of environmental information and control.
434298_1_En_16_Chapter.pdf (479.78 Ko) Télécharger le fichier
hal-01614218 , version 1 (10-10-2017)
Paternité
Guogang Zhao, Haiye Yu, Lianjun Yu, Guowei Wang, Yuanyuan Sui, et al.. Research and Application on Protected Vegetables Early Warning and Control of Mobile Client System. 9th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2015, Beijing, China. pp.155-162, ⟨10.1007/978-3-319-48354-2_16⟩. ⟨hal-01614218⟩
45 Consultations
133 Téléchargements
