Abstract : In order to improve the segmentation accuracy of maize disease leaves with genetic algorithms and reduce segmentation time, this paper proposed a video image recognition technology of maize disease based on the fusion of genetic algorithm and Simulink simulation platform. The technology firstly uses Simulink simulation platform to process the real-time video data captured, including sharpening, segmenting and smoothing, to improve image clarity and quality; Secondly, it uses genetic algorithm to generate optimization model to determine the optimal image of maize diseases; Finally, it fuses genetic algorithms and Simulink platform to analyze and recognize these optimal images. The study results of maize big-spot disease images show that image grey scale values changes after the process of the fused optimal algorithm so that the characteristics of maize diseases are high lightened and the recognition rate of maize disease video image is improved remarkable. The algorithm provides a valid basis for the identification and the diagnosis and treatment of maize disease.
https://hal.inria.fr/hal-01614225 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, October 10, 2017 - 3:44:07 PM Last modification on : Tuesday, October 10, 2017 - 3:53:29 PM Long-term archiving on: : Thursday, January 11, 2018 - 2:02:53 PM
Liying Cao, ying Meng, Jian Lu, Guifen Chen. Research on Video Image Recognition Technology of Maize Disease Based on the Fusion of Genetic Algorithm and Simulink Platform. 9th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2015, Beijing, China. pp.76-91, ⟨10.1007/978-3-319-48354-2_8⟩. ⟨hal-01614225⟩
