Verifying Higher-Order Functions with Tree Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2017
Vérification de fonctions d'ordre supérieur à l'aide d'automates d'arbre
This paper describes a fully automatic technique for verifying properties of higher-order functional programs. Functional programs are modelled with term rewriting systems and tree automata are used to model reachable program states. From a tree automaton representing the initial state, it is possible to define a completion algorithm on tree automata for approximating the output set of the program to verify. We define a subclass of higher-order functional programs for which the completion is guaranteed to terminate. Furthermore, since precision of the completion is fixed by a set of equations, we also propose an algorithm to automatically generate sets of equations by iterative refinement. We present some experiments showing that the resulting verification technique is complementary and extends several state-of-the-art model-checking approaches for higher-order functional programs.
Autre [cs.OH]
Verifying Higher-Order Functions with Tree Automata.pdf (503.35 Ko) Télécharger le fichier
hal-01614380 , version 1 (10-10-2017)
hal-01614380 , version 2 (20-10-2017)
hal-01614380 , version 3 (20-10-2017)
hal-01614380 , version 4 (23-10-2017)
  • HAL Id : hal-01614380 , version 2
Thomas Genet, Timothée Haudebourg, Thomas Jensen. Verifying Higher-Order Functions with Tree Automata. [Technical Report] Irisa. 2017, pp.20. ⟨hal-01614380v2⟩
322 Consultations
270 Téléchargements
