Business Models Based on Co-opetition in a Hyper-Connected Era: The Case of 5G-Enabled Smart Grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sara Moqaddamerad
  • Fonction : Auteur
  • PersonId : 1020554
Yueqiang Xu
  • Fonction : Auteur
  • PersonId : 1020555
Marika Iivari
  • Fonction : Auteur
  • PersonId : 1020535
Petri Ahokangas
  • Fonction : Auteur
  • PersonId : 1020556
This paper aims at introducing a new perspective on devising business models based on the logic of the networked and hyperconnected technological and business environment. The empirical data combines two technological areas: 5G and smart grids. The 5G technology provides rudimentary knowledge about how to create a networked infrastructure for ubiquitous, reliable, and high-speed connectivity. The outcome will enable the utilization of innovative and hyperconnected technologies in the smart grid sector. In the context of the smart grid, we apply a 4C-layered business model that builds on the functional logic of the commercialization of technologies in the 5G era. This eco-systemic business model illustrates how different actors interact in each layer, giving the possibility to identify existing and potential smart grid applications that could be enabled by 5G. We expanded hyperconnectivity into four dimensions, including hyper-connectability, hyper-memorisability, hyper-diffusibility, and hyper-scalability, through an empirical study that can further be developed for a stronger theoretical model of hyperconnectivity.
430868_1_En_47_Chapter.pdf (357 Ko) Télécharger le fichier
hal-01614601 , version 1 (11-10-2017)
Paternité
Sara Moqaddamerad, Yueqiang Xu, Marika Iivari, Petri Ahokangas. Business Models Based on Co-opetition in a Hyper-Connected Era: The Case of 5G-Enabled Smart Grids. 17th Working Conference on Virtual Enterprises (PRO-VE), Oct 2016, Porto, Portugal. pp.559-568, ⟨10.1007/978-3-319-45390-3_47⟩. ⟨hal-01614601⟩
60 Consultations
172 Téléchargements
