Complexity Mitigation in Collaborative Manufacturing Chains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Vladimir Modrak
  • Fonction : Auteur
  • PersonId : 1020587
Slavomir Bednar
  • Fonction : Auteur
  • PersonId : 1020588
Collaborative manufacturing chains (CMSs) are understood as networks of manufacturing units that are highly specialized, cooperation-independent and economically autonomous. CMSs are becoming ever more complex in today’s global market and one pertinent task for supply chain designers/managers is to handle outsourcing decision-making problems, by which such complexity can be reduced. In this paper, we propose to solve this problem through generation of alternative collaborative manufacturing chains that are benchmarked using topological complexity metrics. For this purpose, firstly supply chain structures are modelled. Subsequently, topological complexity measures for each possible configuration network are quantified. Finally, optimal supply chain configurations are selected.
430868_1_En_35_Chapter.pdf (264.51 Ko) Télécharger le fichier
hal-01614621 , version 1 (11-10-2017)
Paternité
Vladimir Modrak, Slavomir Bednar. Complexity Mitigation in Collaborative Manufacturing Chains. 17th Working Conference on Virtual Enterprises (PRO-VE), Oct 2016, Porto, Portugal. pp.411-419, ⟨10.1007/978-3-319-45390-3_35⟩. ⟨hal-01614621⟩
44 Consultations
87 Téléchargements
