Tracking vehicle trajectories and fuel rates in phantom traffic jams: Methodology and data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transportation research. Part C, Emerging technologies Année : 2019
High-fidelity vehicle trajectory data is becoming increasingly important in traffic modeling, especially to capture dynamic features such as stop-and-go waves. This article presents data collected in a series of eight experiments on a circular track with human drivers. The data contains smooth flowing and stop-and-go traffic conditions. The vehicle trajectories presented in this article are collected using a panoramic 360-degree camera, and fuel rate data is recorded via an on-board diagnostics scanner installed in each vehicle. The video data from the 360-degree camera is processed with an offline unsupervised algorithm to extract vehicle trajectories from experimental data. The trajectories are highly accurate, with a mean positional bias of less than 0.01 m and a standard deviation of 0.11 m. The velocities are also validated to be highly accurate with a bias of 0.02 m/s and standard deviation of 0.09 m/s. The source code and data used in this article are published with this work.
WuetAl2017.pdf (13.94 Mo) Télécharger le fichier
hal-01614665 , version 1 (11-10-2017)
Fangyu Wu, Raphael E. Stern, Shumo Cui, Maria Laura Delle Monache, Rahul Bhadani, et al.. Tracking vehicle trajectories and fuel rates in phantom traffic jams: Methodology and data. Transportation research. Part C, Emerging technologies, 2019, 99, pp.82-109. ⟨10.1016/j.trc.2018.12.012⟩. ⟨hal-01614665⟩
902 Consultations
615 Téléchargements
