Alternative opportunistic alert diffusion to support infrastructure failure during disasters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Sensors Année : 2017
Farouk Mezghani
  • Fonction : Auteur
  • PersonId : 1014348
  • IdRef : 189680571
Opportunistic communications present a promising solution for disaster network recovery in emergency situations such as hurricanes, earthquakes, and floods, where infrastructure might be destroyed. Some recent works in the literature have proposed opportunistic-based disaster recovery solutions, but they have omitted the consideration of mobile devices that come with different network technologies and various initial energy levels. This work presents COPE, an energy-aware Cooperative OPportunistic alErt diffusion scheme for trapped survivors to use during disaster scenarios to report their position and ease their rescue operation. It aims to maintain mobile devices functional for as long as possible for maximum network coverage until reaching proximate rescuers. COPE deals with mobile devices that come with an assortment of networks and aims to perform systematic network interface selection. Furthermore, it considers mobile devices with various energy levels and allows low-energy nodes to hold their charge for longer time with the support of high-energy nodes. A proof-of-concept implementation has been performed to study the doability and efficiency of COPE, and to highlight the lessons learned.
sensors-17-02370.pdf (3.03 Mo) Télécharger le fichier
hal-01614744 , version 1 (17-10-2017)
Farouk Mezghani, Nathalie Mitton. Alternative opportunistic alert diffusion to support infrastructure failure during disasters. Sensors, 2017, ⟨10.3390/s17102370⟩. ⟨hal-01614744⟩
Collections
INRIA INRIA2
94 Consultations
112 Téléchargements
