HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Lightweight Journaling for Scada Systems via Event Correlation
Abstract : Industrial control systems are not immune to cyber incidents. However, the support for incident responders and forensic investigators is low. In particular, there are limited journaling capabilities for operator actions. Barring the preservation of full packet captures and operator workstation security logs, which can generate unmanageable amounts of data on production networks, it is generally not possible to attribute control events (e.g., opening a valve or operating a breaker) to individual operators. This information can be necessary to perform security investigations, especially in cases involving malicious insider activities. This chapter presents a lightweight journaling system for SCADA networks based on event correlation. By correlating network events and operating system logs, a journal is generated of all Modbus protocol write events along with the usernames of the operators who performed the actions. The journal is much more compact than a full packet capture, achieving compression ratios of around 570 to 1 in conservative conditions and more than 2,000 to 1 in typical operating conditions, allowing for the preservation of valuable information for security investigations.
Document type :
Conference papers
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01614870
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, October 11, 2017 - 3:00:07 PM
Last modification on : Monday, March 19, 2018 - 10:38:02 PM
Long-term archiving on: : Friday, January 12, 2018 - 3:01:47 PM
File
434671_1_En_6_Chapter.pdf
Identifiers
Citation
Antoine Lemay, Alireza Sadighian, Jose Fernandez. Lightweight Journaling for Scada Systems via Event Correlation. 10th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2016, Arlington, VA, United States. pp.99-115, ⟨10.1007/978-3-319-48737-3_6⟩. ⟨hal-01614870⟩
Share
Metrics
Record views
30
Files downloads
86
