The fault diagnosis technology of mechanical equipment and its application, 2001. ,
Principal component analysis. Chemometrics and intelligent laboratory systems, pp.37-52, 1987. ,
Fault diagnosis based on Fisher discriminant analysis and support vector machines, Computers & Chemical Engineering, vol.28, issue.8, pp.1389-1401, 2004. ,
DOI : 10.1016/j.compchemeng.2003.10.002
The manifold ways of perception, Science, vol.290, pp.2268-2269, 2000. ,
Nonlinear Dimensionality Reduction by Locally Linear Embedding, Science, vol.290, issue.5500, pp.2323-2329, 2000. ,
DOI : 10.1126/science.290.5500.2323
A Global Geometric Framework for Nonlinear Dimensionality Reduction, Science, vol.290, issue.5500, pp.2319-2342, 2000. ,
DOI : 10.1126/science.290.5500.2319
Machinery fault diagnosis using supervised manifold learning, Mechanical Systems and Signal Processing, vol.23, issue.7, pp.2301-2311, 2009. ,
DOI : 10.1016/j.ymssp.2009.02.006
Sparse manifold clustering and embedding, Advances in Neural Information Processing Systems, pp.55-63, 2011. ,
On spectral clustering: Analysis and an algorithm, Advances in Neural Information Processing Systems, pp.849-856, 2002. ,
Laplacian eigenmaps and spectral techniques for embedding and clustering Bearing vibration data set, Advances in Neural Information Processing Systems, pp.585-591, 2002. ,
Multiscale morphology analysis and its application to fault diagnosis, Mechanical Systems and Signal Processing, vol.22, issue.3, pp.597-610, 2008. ,
DOI : 10.1016/j.ymssp.2007.09.010
Fault diagnosis of rolling element bearings using basis pursuit, Mechanical Systems and Signal Processing, vol.19, issue.2, pp.341-356, 2005. ,
DOI : 10.1016/j.ymssp.2004.03.008
