HOπ in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
HOπ in Coq
We propose a formalization in Coq of HOπ , a process calculus where messages carry processes. Such a higher-order calculus features two very different kinds of binder: process input, similar to λ-abstraction, and name restriction, whose scope can be expanded by communication. We formalize strong context bisimilarity and prove it is compatible using Howe's method, based on several proof schemes we developed in a previous paper.
cpp18.pdf (696.44 Ko) Télécharger le fichier
hal-01614987 , version 1 (11-10-2017)
hal-01614987 , version 2 (28-11-2017)
hal-01614987 , version 3 (15-12-2017)
Sergueï Lenglet, Alan Schmitt. HOπ in Coq. CPP 2018 - The 7th ACM SIGPLAN International Conference on Certified Programs and Proofs, Jan 2018, Los Angeles, United States. pp.14, ⟨10.1145/3167083⟩. ⟨hal-01614987v3⟩
1116 Consultations
625 Téléchargements
