HOπ in Coq
We propose a formalization in Coq of HOπ , a process calculus where messages carry processes. Such a higher-order calculus features two very different kinds of binder: process input, similar to λ-abstraction, and name restriction, whose scope can be expanded by communication. We formalize strong context bisimilarity and prove it is compatible using Howe's method, based on several proof schemes we developed in a previous paper.
Théorie et langage formel [cs.FL]
