Automatic Image Annotation Based on Semi-supervised Probabilistic CCA - Archive ouverte HAL Access content directly
Conference Papers Year : 2016
(1, 2) , (2) , (3) , (3) , (4)
1
2
3
4
We propose a novel semi-supervised method for building a statistical model that represents the relationship between images and text labels (tags) based on a semi-supervised variant of CCA called SemiPCCA, which extends the probabilistic CCA model to make use of the labelled and unlabelled images together to extract the low-dimensional latent space representing topics of images. Real-world image tagging experiments indicate that our proposed method improves the accuracy even when only a small number of labelled images are available.
433802_1_En_22_Chapter.pdf (294.24 Ko) Télécharger le fichier
Dates and versions
hal-01614988 , version 1 (11-10-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Bo Zhang, Gang Ma, Xi Yang, Zhongzhi Shi, Jie Hao. Automatic Image Annotation Based on Semi-supervised Probabilistic CCA. 9th International Conference on Intelligent Information Processing (IIP), Nov 2016, Melbourne, VIC, Australia. pp.211-221, ⟨10.1007/978-3-319-48390-0_22⟩. ⟨hal-01614988⟩
55 View
104 Download
Share
