Epistemic Opacity, Confirmation Holism and Technical Debt: Computer Simulation in the Light of Empirical Software Engineering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Julian Newman
  • Fonction : Auteur
  • PersonId : 1020739
Software-intensive Science, and in particular the method of modelling large and complex systems by means of computer simulation, presents acute dilemmas of epistemic trust. Some authors have contended that simulations are essentially epistemically opaque vis and vis a human agent, others that complex simulation models suffer from an inescapable confirmation holism. We argue that the shortcomings lie in the failure of modellers to adopt sound Software Engineering practices, and that the elevation of computational models into superior epistemic authorities runs counter to principles that are common to both Science and Software Engineering.
432590_1_En_18_Chapter.pdf (599.38 Ko) Télécharger le fichier
hal-01615298 , version 1 (12-10-2017)
Paternité
Julian Newman. Epistemic Opacity, Confirmation Holism and Technical Debt: Computer Simulation in the Light of Empirical Software Engineering. 3rd International Conference on History and Philosophy of Computing (HaPoC), Oct 2015, Pisa, Italy. pp.256-272, ⟨10.1007/978-3-319-47286-7_18⟩. ⟨hal-01615298⟩
112 Consultations
156 Téléchargements
