Nominal Reasoning Techniques in Coq, International Workshop on Logical Frameworks and Meta-Languages:Theory and Practice (LFMTP), pp.69-77, 2006. ,
DOI : 10.1016/j.entcs.2007.01.028
Abstracting syntax, 2009. ,
Mechanized metatheory for the masses: The POPLmark challenge, Theorem Proving in Higher Order Logics: 18th International Conference, number 3603 in LNCS, pp.50-65, 2005. ,
Nominal reasoning techniques in Coq: (extended abstract), Electr. Notes Theor. Comput. Sci, vol.174, issue.5, pp.69-77, 2007. ,
Least and greatest fixed points in linear logic, ACM Trans. on Computational Logic, vol.13, issue.1, 2012. ,
Abella: A system for reasoning about relational specifications, Journal of Formalized Reasoning, vol.7, issue.2, p.2014 ,
URL : https://hal.archives-ouvertes.fr/hal-01102709
The Bedwyr System for Model Checking over Syntactic Expressions, 21th Conf. on Automated Deduction (CADE), number 4603 in LNAI, pp.391-397, 2007. ,
DOI : 10.1007/978-3-540-73595-3_28
Program Extraction from Normalization Proofs, Studia Logica, vol.11, issue.1, pp.25-49, 2006. ,
DOI : 10.1007/s11225-006-6604-5
URL : https://hal.archives-ouvertes.fr/hal-00150904
Checking NFA equivalence with bisimulations up to congruence, ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages (POPL), pp.457-468, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00639716
The Locally Nameless Representation, Journal of Automated Reasoning, vol.40, issue.12, pp.1-46, 2011. ,
DOI : 10.1007/s10817-008-9097-2
A lightweight formalization of the metatheory of bisimulation-up-to, Proceedings of the 4th ACM-SIGPLAN Conference on Certified Programs and Proofs, pp.157-166, 2015. ,
Nominal logic programming, ACM Transactions on Programming Languages and Systems, vol.30, issue.5, pp.1-47, 2008. ,
DOI : 10.1145/1387673.1387675
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.342.6780
Parametric higher-order abstract syntax for mechanized semantics, Proceeding of the 13th ACM SIGPLAN international conference on Functional programming, pp.143-156, 2008. ,
A formulation of the simple theory of types, The Journal of Symbolic Logic, vol.1, issue.02, pp.56-68, 1940. ,
DOI : 10.2307/2371199
Natural semantics on the computer, Research Report, vol.416, 1985. ,
Implementing Mathematics with the Nuprl Proof Development System, 1986. ,
The calculus of constructions, Information and Computation, vol.76, issue.2-3, pp.95-120, 1988. ,
DOI : 10.1016/0890-5401(88)90005-3
URL : https://hal.archives-ouvertes.fr/inria-00076024
A Survey of the Project Automath, To H. B. Curry: Essays in Combinatory Logic, Lambda Calculus, and Formalism, pp.589-606, 1980. ,
DOI : 10.1016/S0049-237X(08)70203-9
Lambda calculus notation with nameless dummies, a tool for automatic formula manipulation, with an application to the Church-Rosser theorem, Indagationes Mathematicae, vol.34, issue.5, pp.381-392, 1972. ,
Higher-order abstract syntax in Coq, Second International Conference on Typed Lambda Calculi and Applications, pp.124-138, 1995. ,
DOI : 10.1007/BFb0014049
URL : https://hal.archives-ouvertes.fr/inria-00074124
Implementing HOL in an higher order logic programming language, Proceedings of the Eleventh Workshop on Logical Frameworks and Meta- Languages: Theory and Practice, pp.1-410, 2016. ,
ELPI: fast, embeddable, ?Prolog interpreter, Logic for Programming, Artificial Intelligence, and Reasoning -20th International Conference Proceedings, pp.460-468, 2015. ,
Specifying theorem provers in a higher-order logic programming language, Ninth International Conference on Automated Deduction, number 310 in LNCS, pp.61-80, 1988. ,
DOI : 10.1007/BFb0012823
Hybrid, Journal of Automated Reasoning, vol.18, issue.1, pp.43-105, 2012. ,
DOI : 10.1017/S0956796807006557
The Next 700 Challenge Problems for Reasoning with Higher-Order Abstract Syntax Representations, Journal of Automated Reasoning, vol.10, issue.4, 2015. ,
DOI : 10.1145/2103656.2103709
A new approach to abstract syntax involving binders, Proceedings. 14th Symposium on Logic in Computer Science (Cat. No. PR00158), pp.214-224, 1999. ,
DOI : 10.1109/LICS.1999.782617
The Abella Interactive Theorem Prover (System Description), Fourth International Joint Conference on Automated Reasoning, pp.154-161, 2008. ,
DOI : 10.1007/978-3-540-71070-7_13
Reasoning in Abella about Structural Operational Semantics Specifications, International Workshop on Logical Frameworks and Meta-Languages: Theory and Practice, pp.85-100, 2008. ,
DOI : 10.1016/j.entcs.2008.12.118
Nominal abstraction. Information and Computation, pp.48-73, 2011. ,
DOI : 10.1016/j.ic.2010.09.004
URL : https://doi.org/10.1016/j.ic.2010.09.004
A Two-Level Logic Approach to Reasoning About Computations, Journal of Automated Reasoning, vol.40, issue.4, pp.241-273, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00776208
Separating functional computation from relations, 26th EACSL Annual Conference on Computer Science Logic, 2017. ,
Über formal unentscheidbare Sätze der Principia Mathematica und verwandter Systeme I, Monatshefte der Mathematischen Physik, pp.173-198, 1931. ,
Introduction to HOL ? A theorem proving environment for higher order logic, 1993. ,
Edinburgh LCF: A Mechanised Logic of Computation, LNCS, vol.78, 1979. ,
DOI : 10.1007/3-540-09724-4
A framework for defining logics, Journal of the ACM, vol.40, issue.1, pp.143-184, 1993. ,
DOI : 10.1145/138027.138060
??-calculus in (Co)inductive-type theory, Theoretical Computer Science, vol.253, issue.2, pp.239-285, 2001. ,
DOI : 10.1016/S0304-3975(00)00095-5
seL4, Proceedings of the ACM SIGOPS 22nd symposium on Operating systems principles, SOSP '09, pp.207-220, 2009. ,
DOI : 10.1145/1629575.1629596
Formal verification of a realistic compiler, Communications of the ACM, vol.52, issue.7, pp.107-115, 2009. ,
DOI : 10.1145/1538788.1538814
URL : https://hal.archives-ouvertes.fr/inria-00415861
Choices in Representation and Reduction Strategies for Lambda Terms in Intensional Contexts, Journal of Automated Reasoning, vol.198, issue.1?2, pp.89-132, 2005. ,
DOI : 10.1016/1385-7258(72)90034-0
Mechanizing Proof, 2001. ,
Intuitionistic Type Theory. Studies in Proof Theory Lecture Notes, Bibliopolis, 1984. ,
A logic for reasoning with higher-order abstract syntax, Proceedings of Twelfth Annual IEEE Symposium on Logic in Computer Science, pp.434-445, 1997. ,
DOI : 10.1109/LICS.1997.614968
Cut-elimination for a logic with definitions and induction, Theoretical Computer Science, vol.232, issue.1-2, pp.91-119, 2000. ,
DOI : 10.1016/S0304-3975(99)00171-1
Reasoning with higher-order abstract syntax in a logical framework, ACM Transactions on Computational Logic, vol.3, issue.1, pp.80-136, 2002. ,
DOI : 10.1145/504077.504080
An extension to ML to handle bound variables in data structures: Preliminary report, Informal Proceedings of the Logical Frameworks BRA Workshop, 1990. ,
A Logic Programming Language with Lambda-Abstraction, Function Variables, and Simple Unification, Journal of Logic and Computation, vol.1, issue.4, pp.497-536, 1991. ,
DOI : 10.1093/logcom/1.4.497
Bindings, mobility of bindings, and the -quantifier, 18th International Conference on Computer Science Logic (CSL) 2004, p.24, 2004. ,
Finding unity in computational logic, Proceedings of the 2010 ACM-BCS Visions of Computer Science Conference, ACM-BCS '10, pp.1-3, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00772557
Programming with Higher-Order Logic, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00776197
Uniform proofs as a foundation for logic programming, Annals of Pure and Applied Logic, vol.51, issue.1-2, pp.125-157, 1991. ,
DOI : 10.1016/0168-0072(91)90068-W
A proof theory for generic judgments, 55 Robin Milner. Communication and Concurrency, pp.749-783, 1989. ,
DOI : 10.1145/1094622.1094628
Communicating and Mobile Systems: The ?-Calculus, 1999. ,
Induction and Co-induction in Sequent Calculus, Post-proceedings of TYPES 2003, number 3085 in LNCS, pp.293-308, 2003. ,
DOI : 10.1007/978-3-540-24849-1_19
A mechanically verified language implementation, Journal of Automated Reasoning, vol.5, issue.4, pp.461-49215, 1989. ,
DOI : 10.1007/BF00243133
System Description: Teyjus???A Compiler and Abstract Machine Based Implementation of ??Prolog, 16th Conf. on Automated Deduction (CADE), number 1632 in LNAI, pp.287-291, 1999. ,
DOI : 10.1007/3-540-48660-7_25
A notation for lambda terms a generalization of environments, Theoretical Computer Science, vol.198, issue.1-2, pp.49-98, 1998. ,
DOI : 10.1016/S0304-3975(97)00184-9
A generic tableau prover and its integration with isabelle, J. UCS, vol.5, issue.3, pp.73-87, 1999. ,
Epigrams on programming, ACM SIGPLAN Notices, pp.7-13, 1982. ,
Logic programming in the LF logical framework, Logical Frameworks, pp.149-181, 1991. ,
DOI : 10.1017/CBO9780511569807.008
Higher-order abstract syntax 65 Frank Pfenning and Carsten Schürmann. System description: Twelf ? A meta-logical framework for deductive systems, Proceedings of the ACM-SIGPLAN Conference on Programming Language Design and Implementation 16th Conf. on Automated Deduction (CADE), number 1632 in LNAI, pp.199-208, 1988. ,
Beluga: A framework for programming and reasoning with deductive systems (system description) 67 The POPLmark Challenge webpage, Fifth International Joint Conference on Automated Reasoning, number 6173 in LNCS, pp.15-21, 2010. ,
An Overview of C??ml, Electronic Notes in Theoretical Computer Science, vol.148, issue.2, pp.27-51, 2005. ,
DOI : 10.1016/j.entcs.2005.11.039
Weak bisimulation upto elaboration, LNCS, vol.4137, pp.390-405, 2006. ,
Complete lattices and upto techniques, LNCS, vol.4807, pp.351-366, 2007. ,
DOI : 10.1007/978-3-540-76637-7_24
URL : https://hal.archives-ouvertes.fr/ensl-00155308
Enhancements of the bisimulation proof method, Advanced Topics in Bisimulation and Coinduction, pp.233-289, 2011. ,
DOI : 10.1017/CBO9780511792588.007
URL : https://hal.archives-ouvertes.fr/hal-00909391
The Teyjus system ? version 2, 2015. ,
??-Calculus, internal mobility, and agent-passing calculi, Theoretical Computer Science, vol.167, issue.1-2, pp.235-274, 1996. ,
DOI : 10.1016/0304-3975(96)00075-8
The Seventeen Provers of the World, LNCS, vol.3600, pp.151-157, 2006. ,
Ott: Effective tool support for the working semanticist, Journal of Functional Programming, vol.8, issue.01, pp.71-122, 2010. ,
DOI : 10.1007/BFb0035382
A meta-programming approach to realizing dependently typed logic programming, Proceedings of the 12th international ACM SIGPLAN symposium on Principles and practice of declarative programming, PPDP '10, pp.187-198, 2010. ,
DOI : 10.1145/1836089.1836113
A two-level logic approach to reasoning about typed specification languages, 34th International Conference on Foundations of Software Technology and Theoretical Computer XX:16 Mechanized Metatheory Revisited: An Extended Abstract Science (FSTTCS), volume 29 of Leibniz International Proceedings in Informatics (LIPIcs) Schloss Dagstuhl?Leibniz-Zentrum für Informatik, pp.557-569, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01091544
Model Checking for ??-Calculus Using Proof Search, Proceedings of CONCUR'05, pp.36-50, 2005. ,
DOI : 10.1007/11539452_7
A Proof Search Specification of the ??-Calculus, 3rd Workshop on the Foundations of Global Ubiquitous Computing, pp.79-101, 2005. ,
DOI : 10.1016/j.entcs.2005.05.006
Proof search specifications of bisimulation and modal logics for the ??-calculus, ACM Transactions on Computational Logic, vol.11, issue.2, p.2010 ,
DOI : 10.1145/1656242.1656248
Cut elimination for a logic with induction and co-induction, Journal of Applied Logic, vol.10, issue.4, pp.330-367, 2012. ,
DOI : 10.1016/j.jal.2012.07.007
Nominal Techniques in Isabelle/HOL, Journal of Automated Reasoning, vol.323, issue.1???2, pp.327-356, 2008. ,
DOI : 10.1145/1183278.1183280
From Frege to Gödel: A Source Book in Mathematics, 1879-1931. Source books in the history of the sciences series, 1967. ,
The Machine-Assisted Proof of Programming Language Properties, 1996. ,
