Improving Process Management in a Water Treatment Plant Using Control Modelling - Archive ouverte HAL Access content directly
Conference Papers Year : 2016
(1) , (1, 2) , (3, 1) , (1) , (1)
1
2
3
This work presents a modelling and a simulation of a pH control for process management in a drinking water treatment plant. A range of historical data, or knowledge base, was used to define the behavior of each input and disturbances of the process, using the MATLAB/Simulink software. The present pH control modelling has been simulated and compared to some experimental tests, thus contributing to achieve and identify operational scenarios in a real water treatment plant. Therefore, the present results allows to predict not only the present scenarios but also new operational conditions, in order to estimate the better process parameters and reduce some costs related to raw materials, such as the lime consumption, in water treatment plants.
434863_1_En_17_Chapter.pdf (972.13 Ko) Télécharger le fichier
Dates and versions
hal-01615700 , version 1 (12-10-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Cleber Gustavo Dias, Fábio Santos, André Librantz, Cristiano Sousa, Luiz Silva. Improving Process Management in a Water Treatment Plant Using Control Modelling. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2016, Iguassu Falls, Brazil. pp.138-145, ⟨10.1007/978-3-319-51133-7_17⟩. ⟨hal-01615700⟩
67 View
142 Download
Share
