Logical Decision-Making Method Relating to Innovation Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper is intended to serve as a support for decision in innovation management from the $$ {\text{E}}\uptau $$ Logic. We intend to propose a new method for innovation management, based on technical and operational criteria in order to make decisions can be not only reliable but also operationally efficient. This research presents results that can serve to innovation managers.
434863_1_En_2_Chapter.pdf (636.65 Ko) Télécharger le fichier
hal-01615717 , version 1 (12-10-2017)
Paternité
Nélio Reis, Priscila Tavares, Cristina Oliveira, Jair Minoro Abe. Logical Decision-Making Method Relating to Innovation Management. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2016, Iguassu Falls, Brazil. pp.12-19, ⟨10.1007/978-3-319-51133-7_2⟩. ⟨hal-01615717⟩
47 Consultations
118 Téléchargements
