Abstract : Pull production is a key element for a lean manufacturing system. In pull production, buffer inventories between two processes can be implemented either through a FIFO lane as part of a kanban loop, or through a supermarket, in which case the value stream is split into two different kanban loops. This paper compares the usage of FIFO lanes and supermarkets with respect to the work-in-process inventory needed to achieve a similar delivery performance. The results clearly show that there is only a minor difference in inventory between the usage of FIFO lanes and supermarkets.
https://hal.inria.fr/hal-01615758 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, October 12, 2017 - 4:41:50 PM Last modification on : Thursday, March 5, 2020 - 4:46:19 PM
Denis Wiesse, Christoph Roser. Supermarkets vs. FIFO Lanes: A Comparison of Work-in-Process Inventories and Delivery Performance. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2016, Iguassu Falls, Brazil. pp.651-658, ⟨10.1007/978-3-319-51133-7_77⟩. ⟨hal-01615758⟩
