A Method Towards Modelling and Analysis of Semantically-Enriched Reconfigurable Manufacturing Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Modelling and simulation are two relevant facets for thorough and effective analysis of industrial systems that nowadays have to cope with the evergrowing complexity of the industrial processes and the need of modelling flexibility and knowledge sharing. For all these reasons, the following work seeks to explore and combine together different methodologies by exploiting their best features. In particular, the current research aims to combine semantic technologies, such as ontologies, and high-level Petri nets to revamp the actual assembly systems. Thus, key research concepts are presented, explaining such potential integration and providing a short example of the dynamic configuration of an assembly system within a semantically enriched modelling environment.
434863_1_En_6_Chapter.pdf (44.88 Mo) Télécharger le fichier
hal-01615759 , version 1 (12-10-2017)
Paternité
Damiano Nunzio Arena, Dimitris Kiritsis. A Method Towards Modelling and Analysis of Semantically-Enriched Reconfigurable Manufacturing Systems. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2016, Iguassu Falls, Brazil. pp.45-52, ⟨10.1007/978-3-319-51133-7_6⟩. ⟨hal-01615759⟩
99 Consultations
35 Téléchargements
