Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : Buffers decouple fluctuations in the material flow. It is common wisdom in industry that a full buffer indicates a downstream bottleneck and an empty buffer indicates an upstream bottleneck. Numerous different bottleneck detection methods use this approach to detect the bottlenecks. However, so far this common wisdom on the shop floor has not yet been verified academically. The authors tested this hypothesis using a bottleneck detection method that was able to detect the bottleneck in a system at any given time. The bottleneck direction can reasonably be determined based on the inventory levels of the buffer only for symmetrical systems. In asymmetrical systems, the likelihood of the bottleneck direction is biased toward the bottleneck.
https://hal.inria.fr/hal-01615777 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, October 12, 2017 - 4:42:56 PM Last modification on : Thursday, March 5, 2020 - 4:46:21 PM
Carolin Romeser, Christoph Roser. Direction of the Bottleneck in Dependence on Inventory Levels. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2016, Iguassu Falls, Brazil. pp.667-674, ⟨10.1007/978-3-319-51133-7_79⟩. ⟨hal-01615777⟩
