Non-convex sweeping processes involving maximal monotone operators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optimization Année : 2017
Samir Adly
Le Ba Khiet
  • Fonction : Auteur
  • PersonId : 949887
By using a regularization method, we study in this paper the global existence and uniqueness property of a new variant of non-convex sweeping processes involving maximal monotone operators. The system can be considered as a maximal monotone differential inclusion under a control term of normal cone type forcing the trajectory to be always contained in the desired moving set. When the set is fixed, one can show that the unique solution is right-differentiable everywhere and its right-derivative is right-continuous. Non-smooth Lyapunov pairs for this system are also analysed.
Sadly2017.pdf (312.99 Ko) Télécharger le fichier
hal-01616075 , version 1 (20-09-2018)
Samir Adly, Le Ba Khiet. Non-convex sweeping processes involving maximal monotone operators. Optimization, 2017, 66 (9), pp.1465-1486. ⟨10.1080/02331934.2017.1337765⟩. ⟨hal-01616075⟩
133 Consultations
165 Téléchargements
