A Generic Data Exchange System for Friend-to-Friend Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
Decentralized private networks (a.k.a. darknets) guaranty privacy and concealment of information against global observers. Although a significant number of decentralized data distribution systems ex- ist, most of them target peer-to-peer architectures where any pair of nodes can exchange data using a temporary encrypted connection. Little has been done to achieve the same confidentiality in static darknet architectures, also known as “Friend-to-Friend” net- works, in which participants form a static mesh of nodes, each node only talking to a set of “friend” nodes managed by the user himself. Distributing data over F2F networks requires a specific model of confidentiality and proper algorithms in order to seamlessly spread the information beyond immediate friends nodes. In this paper we present a secure, robust and generic data distribution system that is specifically suitable to F2F networks. The proposed system manages pseudo-anonymous identities grouped into circles, that can be used to limit the access to information. It offers built-in reputation control and an abstract data layer to represent the information to spread. On top of that we present several existing applications to that system, providing the functionality of distributed forums, asynchroneous messaging, distribution channels, and also discuss the possibility to create social networking applications on top of it.
Les réseaux privés décentralisés (ou Darknets) garrantissent la securite des informations contre l’espionnage de masse. Bien qu’une quantité significative de réseaux privés décentralisés existe dans le monde de l’open source, ceux ci sont généralement basés sur une architecture "pair à pair" (P2P) dans laquelle des communications directes sont succeptibles d’intervenir entre toutes les paires de noeud du réseau. Nous nous interessons plus particulièrement à la distribution sécurisée de données dans les réseaux de type "ami ami" (F2F), pour lesquels chaque noeud du réseau ne communique directement qu’avec une liste pré-déterminée de noeuds amis controllée par l’utilisateur. La distribution sécurisée de données sur ce type de réseau demande des algorithmes et un modèle de confidentialité adaptés adaptés Dans ce rapport, nous proposons un système robuste, sécurisé et extensible de distribution de données sur les réseaux F2F, proposant des identités pseudo-anonymes controllées par un système de réputations, et pouvant être regroupées en cercles d’amis pouvant être utilisés pour limiter la distribution des informations. Nous présentons plusieurs applications basées sur ce système, implémentant des forums, des chaines de distribution ainsi qu’une messagerie asynchrone.
RR-9107.pdf (2.33 Mo) Télécharger le fichier
Screenshot from 2017-10-18 14:28:12.png (17.91 Ko) Télécharger le fichier
Format : Figure, Image
hal-01617423 , version 1 (20-10-2017)
  • HAL Id : hal-01617423 , version 1
Cyril Soler. A Generic Data Exchange System for Friend-to-Friend Networks. [Research Report] RR-9107, INRIA Grenoble - Rhone-Alpes. 2017, pp.1-25. ⟨hal-01617423⟩
1078 Consultations
960 Téléchargements
