A distributed finite-time observer for linear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Haik Silm
  • Fonction : Auteur
  • PersonId : 1021010
Denis Efimov
Jean-Pierre Richard
Wim Michiels
  • Fonction : Auteur
  • PersonId : 866458
In this paper, the problem of distributed estimation for a linear large-scale system is studied. A nonlinear distributed observer is proposed, whose estimation error converges to zero in a finite time. A fixed-time converging version of the observer is also presented. The efficiency of estimators is demonstrated by computer simulations.
SUERM-CDC-2017.pdf (247.19 Ko) Télécharger le fichier
hal-01617440 , version 1 (16-10-2017)
hal-01617440 , version 2 (07-11-2019)
  • HAL Id : hal-01617440 , version 1
Haik Silm, Rosane Ushirobira, Denis Efimov, Jean-Pierre Richard, Wim Michiels. A distributed finite-time observer for linear systems. CDC 2017 - 56th IEEE Conference on Decision and Control, Dec 2017, Melbourne, Australia. pp.1-6. ⟨hal-01617440v1⟩
Collections
CRISTAL-SYNER
262 Consultations
478 Téléchargements
