Error estimates for numerical approximation of Hamilton-Jacobi equations related to hybrid control systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics and Optimization Année : 2018
Hybrid control systems are dynamical systems that can be controlled by a combination of both continuous and discrete actions. In this paper we study the approximation of optimal control problems associated to this kind of systems, and in particular of the Quasi-Variational Inequality which characterizes the value function. Our main result features the error estimates between the value function of the problem and its approximation. We also focus on the hypotheses describing the mathematical model and the properties defining the class of numerical scheme for which the result holds true.
Hybrid_FSZ_Hal.pdf (355.57 Ko) Télécharger le fichier
hal-01617686 , version 1 (16-10-2017)
Roberto Ferretti, Achille Sassi, Hasnaa Zidani. Error estimates for numerical approximation of Hamilton-Jacobi equations related to hybrid control systems. Applied Mathematics and Optimization, 2018, ⟨10.1007/s00245-018-9515-8⟩. ⟨hal-01617686⟩
157 Consultations
264 Téléchargements
