Estudo exploratório de um inventário de expressões de espiritualidade na França - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2017
Exploratory study of expressions of spirituality inventory in France.
Étude exploratoire d’un inventaire d’expressions de la spiritualité en France
The concept of spirituality is not new and there is no consensus on it. Several are the philosophical, religious and scientific views and influences that impel the understanding of this theme. Studies on the measurement of spirituality in France are scarce. We found only four studies (Barbier-Bouvet, 2015; Mandhouj, 2015; Branchi, 2014; Velasco et Rioux, 2009). This is one of the reasons that has aroused our interest in developing a research about the expressions of spirituality in France. On the other hand, we find the inventory ESI-R elaborated by MacDonald (2000) that meets our demand. The statistical implicative analysis of the ESI-R involved four studies: analysis of the similarity relation; the implication between the ESI-R items; cohesive analysis and the last study was characterized by the process of reducing the elements research instrument. The results demonstrate that the dimension of existential well-being (EWB) is independently of other dimensions and implies a life without problems and to feel happy. The dimensions of religiosity (REL) and cognitive orientation to spirituality (COS) reinforce the idea that people with a greater propensity to religiousness tend to have greater understanding of the expressions of spirituality. The dimensions paranormal beliefs (PAR) and cognitive orientation of Spirituality (COS) reiterate the thought that people with greater sensitivity and better perception of the spiritual plane (paranormal, mediums, spiritual gurus, etc.) tend to have a greater understanding about the expressions of spirituality.
Le concept de spiritualité n'est pas nouveau et il n'y a pas de consensus à ce sujet. Plusieurs sont les opinions philosophiques, religieuses et scientifiques et les influences qui poussent la compréhension de ce thème. Les études sur la mesure de la spiritualité en France sont encore plus rares. Nous trouvons seulemente quatre études (Barbier-Bouvet, 2015; Mandhouj, 2015; Branchi, 2014; Velasco et Rioux, 2009). Cela est l'une des raisons qui ont suscité notre intérêt pour developper la recherche sur les expressions de la spiritualité en France. D'autre part, nous trouvons l'inventaire ESI-R développé par MacDonald (2000) qui répond à notre demande. Analyse statistique implicative de l'ESI-R a comporté quatre études : analyse de la relation de similarité ; analyse des relations d’implication entre les items ESI-R ; Analyse cohésitive comme celle des relations entre classes de variables. Notons que la dernière étude a été caractérisée par le processus de réduction des éléments de l'instrument de recherche.Les resultats ont permis d'identifier que la dimension existentielle du bien-être (EWB) marche indépendamment des autres dimensions et implique une vie sans problèmes et se sent heureuse. Les dimensions de la religiosité (REL) et l'Orientation Cognitive vers la spiritualité (COS) renforce l'idée que les gens les plus enclins à la religiosité ont tendance à avoir une meilleure compréhension des expressions de la spiritualité. Les dimensions de Croyances paranormales (PAR) et de l’Orientation Cognitive vers la Spiritualité (COS) ont réitèré la conviction que les personnes ayant une plus grande sensibilité et une meilleure perception du plan spirituel (paranormaux, médiums, gourous, etc.) ont tendance à mieux comprendre les expressions de la spiritualité.
O conceito de espiritualidade não é novo e nem há um consenso sobre o mesmo. Diversos são os olhares e influências filosóficas, religiosas e científicas que impelem ao entendimento dessa temática. Os estudos relativos à avaliação da espiritualidade na França são escassos. Encontramos apenas quatro estudos (Barbier-Bouvet, 2015; Mandhouj, 2015; Branchi, 2014; Velasco et Rioux, 2009). Isso é um dos motivos que despertaram o nosso interesse em desenvolver uma pesquisa sobre as expressões da espiritualidade na França. Ao mesmo tempo, encontramos o inventário ESI-R elaborado por MacDonald (2000) que atende nossa demanda. O processo de análise estatística implicativa do ESI-R envolveu quatro estudos: análise da relação de similaridade; a implicação entre os itens ESI-R; análise coesiva e o processo de redução dos elementos instrumento de pesquisa. Os resultados demonstram que a dimensão de bem-estar existencial (EWB) caminha independente de outras dimensões e implica em uma vida sem problemas e sentir-se feliz. As dimensões da religiosidade (REL) e orientação cognitiva para a espiritualidade (COS) reforçam a ideia de que as pessoas com maior propensão à religiosidade tendem a ter maior uma compreensão sobre as expressões da espiritualidade. As dimensões crenças paranormais (PAR) e orientação cognitiva de Espiritualidade (COS) reiteram o pensamento de que as pessoas com maior sensibilidade e melhor percepção do plano espiritual (paranormais, médiuns, gurus espirituais, etc.) tendem a ter um maior entendimento sobre as expressões de espiritualidade.
Fichier non déposé
hal-01618216 , version 1 (17-10-2017)
  • HAL Id : hal-01618216 , version 1
Djailton Pereira da Cunha, Nadja Acioly Regnier, Aurino Lima Ferreira. Estudo exploratório de um inventário de expressões de espiritualidade na França. Jean-Claude Régnier, Régis Gras, Raphael Couturier, Antoine Bodin. Analyse Statistique Implicative. Points de vue conceptuels, applicatifs et métaphoriques, Université Bourgogne Franche Comté - UBFC - IUT Belfort Montbeliard, pp.572-590, 2017, ISBN version imprimée 978-2-9562045-0-3 ; ISBN version numérique 978-2-9562045-1-0. ⟨hal-01618216⟩
96 Consultations
0 Téléchargements
