Dipole recovery from sparse measurements of its field on a cylindrical geometry
We consider the inverse problem of recovering the position and moment of a magnetic dipole
from sparse measurements of the field it generates, known on sections of three orthogonal cylinders
enclosing it. This problem is motivated by recent measurements performed on Moon rocks, in view
of determining their magnetic properties. The key ingredient of the presented method is the use
of rational approximation techniques, together with properties of the poles of the approximants, in
order to estimate the position of the dipole.
