Thoughts on Movement, Growth and an Anthropologically-Sensitive IS/Organization Studies: An Imagined Correspondence with Tim Ingold - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tim Ingold
  • Fonction : Auteur
  • PersonId : 1021161
Lucas Introna
  • Fonction : Auteur
  • PersonId : 1021162
Donncha Kavanagh
  • Fonction : Auteur
  • PersonId : 1021163
Séamas Kelly
  • Fonction : Auteur
  • PersonId : 1021164
Wanda Orlikowski
  • Fonction : Auteur
  • PersonId : 1021165
Susan Scott
  • Fonction : Auteur
  • PersonId : 1021166
In what follows, we present the outcome of an imagined dialogue with Tim Ingold on possible future directions for an anthropologically-sensitive approach to studying Information Systems (IS) and Organization Studies (OS). The aim is to try to convey some of the strangeness and freshness that we have found in his thought, with a view to stimulating IS/OS scholars to engage further with his work and ideas. The piece takes the form of an imagined Q&A session with Tim, which we have synthesized from excerpts of previously published interviews and writings.
434865_1_En_2_Chapter.pdf (344.59 Ko) Télécharger le fichier
hal-01619204 , version 1 (19-10-2017)
Paternité
Tim Ingold, Lucas Introna, Donncha Kavanagh, Séamas Kelly, Wanda Orlikowski, et al.. Thoughts on Movement, Growth and an Anthropologically-Sensitive IS/Organization Studies: An Imagined Correspondence with Tim Ingold. Working Conference on Information Systems and Organizations (ISO), Dec 2016, Dublin, Ireland. pp.17-32, ⟨10.1007/978-3-319-49733-4_2⟩. ⟨hal-01619204⟩
97 Consultations
364 Téléchargements
