, the PIE present *b?rém-e/o-reflected for example in Lat. frem? and Welsh bref-'to low, bleat
, Gr. ????? 'to look' and Gr. ???????? 'eyelid'
, This pseudo-participle is likely to have resulted from an older nasal theme Gr. *??????, -????. 58 It would have derived from Com. Gr. *blék?on reflecting Substr. *bléKwon-< PIE *b?lé?-?-onwith application of the posttonic fortition introduced above. The underlying root is PIE *b?le?-'sparkle, shine' (LIV²: 86), attested for example in Lat. fulge? 'glitter', in inherited Gr. ????? 'to burn, light' and, interestingly from a semantic point of view, To. B palyka/To. A pälk?t [pret.] 'saw' (Hackstein 1995: 112-113 15 ). Note also ???????? [n.] 'eyelid', a singulative from plural ???????, itself probably from an older athematic singular *?????? < Com. Gr. *blék??ar from Substr. *bléKwr? < PIE *b?lé?-?-r? 'wink'. 59 These etymologies suggest that the treatment PIE *#b?r-> Substr. *#br-also applies to liquids (PIE *#b?l-> Substr. *#bl-). Therefore, Gr. ????? (+acc.) 'to look' is probably a late pseudo-verb created on the basis of Gr. ??????, ????????? 'looking
???????? 'vault of a roof, roof (beam)' and Gr. ????????? '(vault of a) roof ,
vault of a roof, roof-beam, roof' (plural: 'dwelling, house') cannot be directly compared to the adjective ??????? 'high' ( < Com. Gr. ???????), which shows the expected outcome of a PIE etymon *ml? h?-d?-r-ó-, with the expected outcome -??-of the long sonorant inherited from PIE *-l? h?-(Beekes 2010: 923, s. v. ????????). We do however believe that both words belong to the PIE root *melh?-'to emerge from, pp.433-434 ,
, For a parallel, see the pseudo-verb ???? 'to be sober' created from its participle ?????, -?????, together with the dative plural form ?????? in Theognis, 1994.
, We believe that the word is indeed not inherited, but that the connection with the PIE root *(s)pelH-holds. We start from a PIE neutral substantive *(s)pélH-tr? 'splitting, defecation', with the same well-known word-formation pattern as suggested above for Gr. ????????. 61 This would have yielded Substr. *spélaTr? 'dung' borrowed as Com. Gr. *spélat?ar 'id, Forms with an initial ?-are also attested, namely the optative ?????????? (Alcman) and the noun ???????? (Alcman, Pindar)
, droppings of goats and sheep' (obscure) and Hom. Gr. ????? [m.] 'dung, excrement of animals' (? 775, 777), from PIE *son-d?h?-ó-'set apart
, Gr. ???????? 'cleft, abyss'
200, s. v. ????????), in view of these variants, the word is Pre-Greek and the connection with ???????? 'devour' cannot be maintained. Indeed, PIE *g?erh?-/*g?r? h?-'devour' (cf. Lat. uor?re 'id.') would yield Gr. **????-/???-(< Com. Gr. *g?ero-/*g?ro-). The odd variant ?????? is explained as a shortened variant of ???????? by Szemerényi (1964: 261), who assumes that a former *brét?ron underwent a dissimilation, *brét?ron itself being syncopated from ????????, following the same pattern as Gr, cleft, abyss' is an obscure form which is related to Hom. Gr. ????????, Arc. ???????? and the Hesychian gloss ?????? [Euphorio]? ?????, ??????????? 'pit, prison'. According to Beekes, 2010. ,
, 208 56 ), with a regressive vowel assimilation *e-a > a-a that is also attested in Greek, next to the progressive assimilation *e-a > e-e previously mentioned. 63 Another problem is that the laryngeal *h? is reflected as Gr. ?, which can no longer be accepted as a valid Greek treatment. Yet such a treatment, with a-vocalisation of laryngeals, is attested in many Indo-European languages, including our substrate language as discussed above for Gr. ????????. We assume a PIE etymon *g?érh?-tr? [n.] 'swallowing', with a secondary plural *g?ér(h?).tr-eh? 'clefts, abysses' endowed with a concrete meaning, Gr. ???-instead of Gr. ????-as found in ????-???? < Com. Gr. *g?éra-t?ron (cf. Semerényi 1964: 215 5 and Kury?owicz, 1956.
, GEW: 2, 763, s. v. ???????? mentions Ger. scheißen 'to defecate' < *'to separate' (cf. PIE root *s??ei? d-'to cut, separate')
??????? 'greatness' next to Gr. ????? 'great' from PIE *mé?-h?, already cited above ,
, flat stone' if from *???????? (Ved. prathimán-'wideness'). several treatments in common with Hittite ((#)D? > (#)T, C?r? C > CurC) and even more so with Tocharian, besides the fact that all these languages are centum. 1. Centum treatment: ? > K 2. Laryngeal treatment: CHC > C?C 3. b?R > bR
, Metathesis of non-syllabic liquids: CVRC > CRVC (before step 10 because of Lat. corbis before step 11 because of Gr. ??????)
, Schwa epenthesis of the form #(s)klV-> #(s)k?lV
, Verner-like lenition and fortition rules: P > P?/V?(R)(s)_ and P > B/_(R)(s)V?, where P denotes any stop
, This matches the town name ?????? 'Crotone' located in Calabria, Southern Italy. The following scenario can therefore be suggested. First, ancestors of Greek (i. e. speakers of Common Greek, 3rd millennium BC) could have been in contact with speakers of our substrate language, most probably before entering Greece. Later on, (some of) the speakers of our substrate language could have reached Southern Italy, founding cities such as Crotone, and (later?) have been there in contact with speakers of Italic languages as they spread over the Italian peninsula (end of the 2nd millennium BC). This would account for the borrowings in both (Common) Greek and (Late Common) Italic as well as for our suggestion regarding the etymology of the city name ??????, Nasal anticipation: VPNV > VNBV 10. Resyllabification: C?r? C > CurC 11. Word-initial treatments: #pr > #br and #tr > #Tr 12
, Abbreviations DLG, vol.2
?timologi?eskij slovar' slavjanskich jazykov. Moskva: Nauka, Griechisches etymologisches Wörterbuch. 3 vols, 1960. ,
, Lexikon der indogermanischen Verben. Die Wurzeln und ihre Primärstammbildungen, Litauisches etymologisches Wörterbuch. 2 vols. Göttingen & Heidelberg: Vandenhoeck & Ruprecht, Winter. LIV² Helmut Rix, 1935.
A Dictionary of Tocharian B. Revised and greatly enlarged. 2 vols, 2013. ,
Etymological Dictionary of Greek. With the assistance of Lucien van Beek. 2 vols, 2010. ,
Pre-Greek. Phonology, Morphology, Lexicon, 2014. ,
, Sa balkanskih isto?nika. Belgrade: Srpska knjiievna zadruga, 1969.
Dictionnaire étymologique du Proto-Indo-Européen, 1955. ,
Dictionnaire étymologique de la langue grecque. Histoire des mots, 2009. ,
Etymological Dictionary of Latin and the Other Italic Languages, 2008. ,
Etymological Dictionary of the Slavic Inherited Lexicon, 2008. ,
Die wichtigsten konsonantischen Erscheinungen des Vorgriechischen, 1972. ,
, Rev. of Beekes, vol.303, pp.332-334, 2014.
La dérivation inverse en latin, 2016. ,
, Vorgriechische Sprachwissenschaft. Sofia: Sofijski Universitet Kliment Ochridski, 1941.
Die Wurzelnomina des Germanischen und ihre Vorgeschichte, 1995. ,
Die Lehre von den indogermanischen Substraten in Griechenland, Linguistique Balkanique, vol.1, pp.29-56, 1959. ,
Untersuchungen zu den sigmatischen Präsensstammbildungen des Tocharischen, 1995. ,
, Historische Sprachforschung, vol.115, pp.1-22, 2002.
Recent developments in mediterranean «substrate» studies, Minos 9, vol.1, pp.219-235, 1968. ,
Entlehnungen aus einer bisher unbekannten indogermanischen Sprache im Urslavischen und Urbaltischen, 1989. ,
Ancient languages of the Balkans, 1976. ,
Evening dress: The metaphorical background of Latin uesper and Greek ???????, Proceedings of the 11th Annual UCLA Indo-European Conference, pp.69-93, 2000. ,
An Indo-European substratum in Slavic?, pp.253-260, 2003. ,
Die protindogermanische Schicht, Glotta, vol.14, pp.300-319, 1925. ,
Etymological Dictionary of Proto-Germanic, 2013. ,
L'apophonie en indo-européen. Wroc?aw: Zak?ad Imiena Ossoli?skich, 1956. ,
Linguistique préhellénique, Revue des Études Anciennes 49, vol.1, pp.25-37, 1947. ,
Etymological Dictionary of Proto-Celtic, 2009. ,
Substratum words in Balto-Slavic, Filologija 60, pp.75-102, 2013. ,
Historische Laut-und Formenlehre der lateinischen Sprache, 1998. ,
Fair play for 'Pelasgian, Lingua, vol.18, pp.144-167, 1967. ,
Rev. of Carnoy, The American Journal of Philology, vol.79, pp.85-90, 1955. ,
Die Etymologie von altgriechischem ?????, Glotta, vol.80, pp.114-125, 2004. ,
The name of Achilles, Cambridge Classical Journal, vol.32, pp.162-173, 2007. ,
The 'Saussure Effect' in Latin and Italic". In: Sound Law and Analogy. Papers in honor of Robert S. P. Beekes on the occasion of his 60th birthday, pp.181-203, 1997. ,
, Indogermanisches etymologisches Wörterbuch, vol.1, 1959.
Syncope in Greek and Indo-European and the nature of Indo-European accent, 1964. ,
The development of the Indo-European mediae aspiratae in Latin and Italic, Scripta minora. Selected essays in Indo-European, Greek and Latin, pp.628-693, 1991. ,
Le pélasgique. Essai sur une langue indo-européenne préhellénique, 1952. ,
A Latin-Hittite Etymology, Language 45, vol.2, pp.235-242, 1969. ,
On the non-verbal origin of the Greek verb ?????? 'be sober, Historische Sprachforschung, vol.107, pp.91-98, 1994. ,
